Post your latest oil change
2002 gmc sierra 140k miles, 5k on fill of NAPA 5-30 DINO, with a NAPA silver filter, Put 5 quarts of rebate Castrol GTX and a rebate purolator filter
Friends GMC Jimmy 99 129k miles 5k on oil, tossed a ST with 5 quarts of Valvoline WB.
2008 YARIS sedan : 3 quarts + 22 ounces SHELL 5w-30 conventional with TOYO oil fiter . Changed out the oil and filter due to being 1/2 quart to full , leaking TOYO oil filter ( not tight , could unscrew by hand ) , and having F.P.I.G. sealant in it from the replacement of the head cylinder gasket at the TOYO service center under warranty . Next fill likely to be PENNZOILs' new 5w-30 due out in OCTOBER .
2010 HHR LS
2.2L 4-cyl Engine Code LE8 Flex-fuel
5qts Valvoline SynPower 5w-30 & Wix 57082
saved bottle rings. will send in 5 tomorrow with form and receipt for $25 rebate.
2009 Hyundai Accent GS 9500 miles. Severe service.
3.5 quarts Pennzoil Ultra 5W30
Hyundai OEM filter
Changed the wife's car to PU from Castrol Syntec.
2006 Ford Mustang GT at 26,400 miles, just bought it...
Used Motorcraft FL-820-S Filter
6 Quarts Mobil-1 5W-20
Originally Posted By: Colt45ws
2009 Ford Fusion SEL
6 qts Schaeffers 7000 Synthetic Blend 5W20
Purolator PureOne PL24651
23,600 miles
I see your Mom got a Fusion? Cool, I use the same oil in my '10 Fusion.
2006 Ford Taurus SEL with 69K miles, 3.0L Vulcan engine: 4.75 quarts of Motorcraft Full Synthetic 5W-20 and a Fram Tough Guard PH3600 (gray) filter. Previous fill MC syn blend 5W-20.
1998 Mercury Mystique SL with 117K miles, 2.5L DOHC Duratech 24v V6: 5.8 quarts of Valvoline MaxLife syn-blend 5W-20 (about half-a-quart of GC 0W-30 added)and a Motorcraft MFL820 filter. Previous fill GC 0W-30.
Father's car: 1999 Pontiac Grand Prix 3800 L36
out: PYB 5w30, PF52
in: PYB 10w30, PF52
7 months, mileage unknown around 2000. OLM light didn't trip but was reset at each change. No % display for OLM.
2006 toyota corolla 1.8l 1zz - pp 5w-30 and a napa gold filter for 5k
2006 dodge ram 2500 5.9 ctd - delo 15w-40 and a fleetgauard stratapore filter for 5k
1992 toy pickup 22re-st 20w-50 and a st filter for 3k
1998 ford explorer 4.0 sohc
Maxlife 10w40 with Motorcraft
2004 VW golf 2.0 BEV
Rotella T 5w40 P1
2000 Chevy Cavalier 2.2
Maxlife 5w30 with fram TG
2011 Hyundai Sonata
Valvoline Synpower 5W-20,found it at O'Rileys for $3.99 a quart.There is also a $25.00 rebate if you buy 10 quarts,So 10 quarts of Synpower ended up costing me $15.00 ($1.50 per quart)
Changed factory oil out at 2200,now I have 5770 miles.
planning on 5-6,000 oci's
Today - 2010 Mustang at a Mobil-1 Lube place...asked for Mobil-1 oil and filter - went for coffee. Time to pay, seemed too cheap, but noticed they used Motorcraft semi-syn. Oh well - figured I'd run it for 3k. Got home, noticed they put in 5W20 instead of 5W30 (OEM req'd). Put car on ramps to install fog lights - that went so good I elected to dump the 5W-20 "engine flush" and refill with Mobil-1 5W-30 and left the filter on.
Good thing you caught it! Another case for DIY oil changes!
