Post your latest oil change
New to me 2002 GMC Envoy SLT 4WD 210,xxx
Out: Oil/Purolater Red
In: 6 qts Havoline HM 5w30/1 qt Castrol Magnatec 5w30 with MMO Filter- AC Delco PF61E
Drain/Fill both diffs: Out- Gear Oil In- Supertech Synthetic 75w90
Trans Pan Drop: Filter- Carquest 96080 Fluid- Supertech HM ATF
Pwr Steering: Supertech PS w/ Stop Leak
Brake: Supertech DOT 3
T-Case: Valvoline Transfer Case Fluid
Windshield Washer: Supertech Purple
Bonus: 6 AC Delco Iridium 41-103 Spark Plugs
Bosch Blue Ceramic Pads FR- BE882H & RR- BE883H
Air Filter: Carquest R87729
Fuel Filter: Carquest 86129/4 zip ties
Throttle Body/Mass Airflow cleaned using CRC 5111
Fuel System Cleaner: Berrymans B-12 Chemtool
2012 Ram Cummins 2500
Out- 3 gallons of Mobil Delvac 1300 15W40 & Mopar MO-285
In- 3 gallons of Mobil Delvac 1300 15W40 & Mopar MO-285
Mileage on truck- 96,470
Mileage on oil- 7,673 miles
Filter C&P is in the filter forum. Oil sample sent to Blackstone
Napa's oil is made by Valvoline, but Carquest seems to come from either Amalie, Coastal/Irving, or Warren Oil(not Warren Distribution). You can tell which by looking at the dexos license number on the Jug, Amalie will end in 049, Warren in 028, and Coastal/Irving in 060
I read a post here where people here talked about it and it was pretty much decided that Carquest was rebranded Valvoline. I didn't come up with this idea. I already tossed the jug. It's ok either way. I usually go 3 or 4 thousand miles between changes.
2018 Mercedes-Benz GLE350 AMG, 31,500 miles
Out: Unknown, MB Filter
In: M1 0W-40 Euro, Mann HU7025Z
About 90% sure it was the factory fill. Drain plug had definitely never been removed and it had an OE MB filter. Customer had been taking it to a chain store and was billed for oil changes and tire rotations twice. I believe the tires had not been rotated either
I’ve always wondered what’s inside these people head who buy an expensive MB truck and take it to a chain store for servicing.
1978 GMC Caballero Diablo
Warmed over 305 small block V8 with Fitech EFI
Out: Amsoil Dominator 15w50, Wix 51069 filter
In: Amsoil Dominator 15w50, Wix 51069 filter
1998 Ford Mustang GT
4.6 V8
Out: Havoline Synthetic 5w20, Motorcraft FL820S filter
In: Amsoil XL 5w20, Wix 51372 filter
2003 Chrysler PT Cruiser
2.4 4 cylinder
Out: Mobil 1 5w30, AcDelco PF53 filter
In: Amsoil XL 5w30, Wix 51348 filter
1979 Chevrolet Camaro
400 small block V8
Out: Valvoline VR1 10w30, AcDelco PF454 filter
In: Amsoil Z Rod 10w30, Wix 51069 filter
1990 Dodge Ram D150
5.2 V8
Out: unknown, Motorcraft FL1A filter
In: Amsoil Signature series 10w30, Wix 51515 filter
'17 Subaru Crosstrek ( see signature )
draining: RGT 5W20 and Fram Ultra note: not a good combo
installing: Subaru Genuine (Idemitsu) 0W20 and Subaru service part Filter note: Easy revving and smooth
What do you think the issue was? I would assume the oil than filter but I'm no expert.
Subaru filters are FRAM-style filters, but not the ULTRA model. The bypass setting was lower on the Ultra.
I think the oil was just too viscous and shear resistant compared to the ultra light Subaru oil 0W20 designed for this engine.
A Crosstrek is about as far from a "Gas Truck" as you can get - even though Shell's appellation is more marketing than anything.
I would bet when installed, the more rackety 2.5L would accommodate RGT more readily than the 2 litre FB motor.
But in 5W30 flavours, I have stated many times that Valvoline Advanced was the best domestic synthetic Ive tried so far in the past couple decades
1985 Chevrolet S10
2.8 V6
Out: Quaker State Advanced Durability 10w30, AcDelco PF47E filter
In: Havoline High Mileage 10w30, AcDelco PF47E filter
1993 Ford Thunderbird
3.8 V6
Out: Pennzoil Conventional 10w30, Motorcraft FL400S filter
In: Valvoline Advanced Synthetic 10w30, Napa Gold 1516 filter
1992 Dodge Dakota
5.2 V8
Out: Chevron Supreme conventional 10w40, Mopar MO-090 filter
In: Amsoil Premium Protection 10w40, Wix 51085 filter
I have a fuzzy memory or reading somewhere that MB or other Euro maker is sucking the oil out now instead of draining. I don’t know, maybe I dreamed it.
Possible. My '98 was dealer maintained and the drain plug looked like it had never been removed. The oil had quite a bit of break-in shavings as well as some black dirt/grit for the first two oil changes i did when i got it last year.
I have never used an Ultra nor the RGT. I have used Amsoil filters and Mobil1 AFE in my Legacy. I'm switching over to M1 EP and I bought a 12 pack of Subaru filters. Since I had 2 Subaru's the 18 Legacy and a 19 Impreza I can share oil and filters. My Impreza is the same engine as yours though I don't know if they are tuned the same way.
Mercedes does that. BMW does it too. The point here was that it still had OEM filter, and I agree with that. Don’t believe a chain store would specifically source the MB branded filter, just almost not possible.
2012 Hyundai Accent GLS - 112,642 miles
3837 mile OCI
OUT:
3 quarts of Valvoline Synthetic Maxlife 0w20
½ quart of Rotella T6 Multi Vehicle 5w30
Fram Titanium FS9688 oil filter
IN:
Fram Titanium FS9688 oil filter autopsy coming soon!
