Post your latest oil change
2019 VW Passat Wolfsburg 2.0TSi
Out: Dealer- Castrol Edge Professional LL 0W-20
Out: Dealer- VW (Mann)
Distance traveled- 5,000 miles
In: VW High Performance Genuine Engine Oil 0W-20
In: VW (Mann)
Current miles- 9,200 miles
1998 Honda Accord LX 4 banger, 109K, 5,300 OCI
Out: Valvoline Syn HM 5w30, Wix filter
In: Kirkland Syn 5w30, Fram UG3593A
Also serviced trans and plugs.
Runs like new.
I used Shell rotella gas truck 5w20 with a little bit of Lucas high mileage oil stabilizer. Used a premium guard extended performance filter. Runs pretty smooth in my 2010 jeep commander.
2008 Jeep Wrangler 3.8, 138k miles on the odo and running like new.
Out: Valvoline Modern Engine 5w20 with about 6100 miles on it.
In: 5 quarts Rotella Gas Truck 5w20, 1 quart 0w20. (I bought it on AZ clearance and they had no singles left in 5w20.)
Filter: The XG3614 that was installed with the Valvoline is going another round.
Note: 6k oil changes are due to Jeep lifetime warranty requirements. Otherwise I'd run it 10k. It drinks oil, so by 6k much of it is new, anyway, Lol! I'll be adding RTG 5w30 as it drinks, because that's the rest of what I found on clearance. Besides, it'll be warming up as Spring comes, so transitioning to a summer weight is good anyway, even if gradual.
2007 Volvo V70 @ 102K. 7,700 on oil
OUT: Formula Shell 5W-30 conv.
IN: 5 qt. Car Quest Full Synth. 5W-30, 1 qt. Spectrol 5W-40 synth.
FILTER: STP S8712 emergency purchase as both Denso filters I had came with the wrong O-ring.
Never thought checking the O-ring's size before doing an oil change was necessary until now.
I'm just glad the AutoZone near me had a filter which fit....at 4;30PM...on a Saturday.
Changed the oil on my new to me 2016 Ford Edge with 2.0 Ecoboost
Dealer changed the oil on it but when I checked the dipstick it was black and smelled like gas.
I decided to change the oil right away with a good oil and flush the system as I don't know the maintenance history. I'll probably run this oil for a few weeks and change it again just for piece of mind (and I have a big stash of oil and filters)
Mileage 64,755
Out: unknown (dealer fill) motorcraft fl910s
In: 6 quarts Pennzoil ultra platinum 5w30 Motorcraft Fl910s
2015 Camry
98000 miles
Out Valvoline syn 0w20 @ 8000 miles, Fram ultra at 18000 miles.
In Valvoline syn 0w20, fram ultra.
Also did the plugs and coolant.
Had a lot of trouble getting the stupid canister off. Using ramps from now on.
2 oil changes.
First in my brothers Edge with the 3.5. I was changing the oil in the PTU and went ahead and changed the oil. I think it had castrol magnatec 5w20 in it with a Defense oil filter D10575.
Put in Castrol Edge 5w20 full syn with an MC 500s
My dads 05 Explorer with the 4.0 took out Maxlife 5w30 with a Quakerstate 173 filter.
Installed. Blue supertech st2 and filled with suptech full syn hm 5w30
Originally Posted by Black_Thunder
2 oil changes.
Everyone likes pictures! Thanks!
2010 Camry I4 with 206K and unknown OCI. Last OC was done at the Walmart where my granddaughter works. The oil filter housing is not the same one that was on the car the last time I changed the oil. The internals of this housing were screwed up. I had to replace the housing.
Out: whatever Walmart used
In: M1 HM 5W30 and ST9972
On a second note, she had been having hesitations when driving. She did not want to bother me so she took it to a mechanic. The mechanic said he found about a dozen codes and needed a lot of work. He even furnished her with a hand written list of the codes. A week later I checked for codes and found none. And 2 weeks later still no codes. I told her to never go back to that mechanic. I tried a couple of things and was finally able to fix the hesitations by cleaning the throttle body.
My new-to-me 2018 Nissan Rogue, I just bought it a few weeks ago with 41,000 miles on it.
Out: Unknown oil, probably bulk 5W30 conventional and Nissan OEM filter
In: STP 0W20 Synthetic and a new Nissan OEM filter
02 Buick regal
3.8 v6
Out: napa 5/30, napa proselect filter
In: napa 5/30, napa proselect filter
14 jeep grand Cherokee
3.6 v6
Out: unknown, unknown filter
In: napa 5/20, napa gold filter
Originally Posted by sopususer
Vehicle: 2019 Chevrolet Silverado Crew 4x4 Z71
Engine 5.3L V8 5K on unit/ 5K oci
Out: 8 quarts factory fill and/Factory AC Delco filter
In: 8 quarts NAPA 0W-20/ 1 AC Delco PF63E filter
[Linked Image]
Member Sopususer just got caught being a nonSopususer......lol
Vehicle: 2019 Subaru Ascent
Engine: FA24 Turbo
Out: Pennzoil 0W20 + 5oz Hy-Per Lube HPZ212 w/ Subaru filter
Miles on oil: 4362
In: Pennzoil 0W20 + 5oz Hy-Per Lube HPZ212 w/ Subaru filter
Engine: FA24 Turbo
Miles on oil: 4362
Why the added Zinc supplement with your 2019 Subaru Turbo?
