Post your latest oil change
2019 Ford F-250 6.2L V8, 16,900 mi.
Out: Mobil 1 10w30, Bosch 3010, ~8,400 miles on oil. OLM was at 0%
In: Mobil 1 Extended Performance 5w30, Bosch 3010
2002 Ford Ranger 3.0L V6, 249,900 mi.
Out: Harvest King 10w30 syn, Bosch 3422, 10,085 miles on oil. Sample sent for UOA
In: ROTELLA Gas Truck 5w30, Bosch 3422
Vehicle
2002 Chevy Tahoe
5.3L V8 FFV
259,800 miles
OCI
9,600 miles
Out
6 quarts Driven LS30 5w30
Fram Ultra XG9837 filter
In
6 quarts High Performance Lubricants BAS 5w30
[Linked Image]
[Linked Image]
Mobil 1 Extended Performance 0w20 6.5 quarts
M1 M1C-251A filter
That's with approximately 4,000 miles mixed city/highway.
Probably 60% city / 40% highway.
Observations?
IMHO that's dang clean looking oil in any vehicle with 4,000 accumulated miles since the last oil change; regardless of oil brand, weight/viscosity, formulation, and oil filter in use.
2018 Hyundai Elantra 2.0 20K miles
Out: Quaker State Ultimate Durability 5w20 and OEM filter
IN: Pennzoil Ultra 5w20 and OEM
6300 miles on previous OCI
1st oil change on the new-to-me 2005 Jeep Grand Cherokee with the 5.7 Hemi. Used O'Reilly's 5W-20 Full Synthetic with a MicroGuard filter. Found out the previous owner used a quick lube place with the wrong filter...
2015 Kia Soul+ 2.0. 75K miles. Son's car. Was a rental car for first 50K miles. No oil change records of course. Spec is for 5W-20, but I observed consumption issues, so have switched to Valvoline 5w30 MaxLife to try and slow burning. I also changed the PCV valve and ran some Rislone for the last 1K miles of last OCI to combat possible sticking piston rings. One or all of that has eliminated the burning. 800 miles into this OCI and zero consumption. Last oil used was Mobil 1 Extended Performance 5w30. 5K OCI.
35K Km OC on a friends Citroen DS3 1.6THP (Turbo Port FI) with 150K km on the ODO
Out : Unknown mixed with top ups of 0W30
In : Shell Helix Ultra AF 5w30 A5/B5
[Linked Image]
2017 GMC 2500 6.0L gasoline engine. 85,600 kms on truck 1958 hours.
out; 5w30 fast lube Dexos and tiny filter.
in; 5w30 Mobil 1 and long Wix.
The 5w30 had no oil pressure at -35C (-41C overnight in north-west Alberta) when started.
The shut engine off message came on after 15 seconds.
After a minute, I started the engine again for 10 seconds, then shut it off.
I got oil pressure on the 3rd try.
Next winter it will be 0Wxx.
edit; The bearings should self-pump as long as there is oil in the galleries.
Originally Posted by spacekiller67
35,000 km OCI on a friends Citroen DS3 1.6THP (Turbo Port FI) with 150K km on the ODO
Poor thing. Does it usually go that long between oil changes?
