Post your latest oil change
2008 Pontiac Grand Prix, 3.8L ("the 3800") non-supercharged, 170,148 miles on car
Out: Mix of Castrol Conventional and Mobil Super HM 10w-30, Purolator PL10111 Oil filter
In: 4.5 Quarts Delo XLE 400 10w-30 Synthetic Blend (CK-4/SN), ACDelco PF47E
The Series III 3800 is spec'ed for 5w-30, but I like running 10w-30 (spec for Series II) during the warmer months.
This car consumes about 1 quart every 1,000 miles (bad piston rings). Other than the oil consumption, the car is great. I'm sure there will be little to no difference in consumption, but for [censored] and giggles I decided to throw in diesel oil which I found on sale and also happened to be dual rated CK-4/SN. I plan on leaving this fill in until November/early December, which will probably be somewhere around 7k-10k miles. Any input appreciated.
Scuse my ignorance but why running a 10w30 when its hot and not a 5w30 all year long ? a 30 is a 30 isnt ?
Especially in a conventional the 10w30 has much less viscosity index improvers which can make it a more stout oil apparently. This is even true with synthetics in a lot of cases which I used to be unaware of. I've recently switched to 10w30 in my old engines because of this.
I run the 10wt in the summer because I am unsure when the blowby occurs (when it's cold or hot or maybe even both, which I assume) so the 10W, even if it's not 0 degrees out, will be a tad bit thicker at startup. Also since 10w30 is obsolete for newer cars in the US, I have been able to find great deals on it. The oil I took out of here I paid $1/qt for name brand oil (and $10 for the whole oil change).
As caprice_2nv said, it does have less viscosity index improvers so it *should* hold it's grade better (theoretically, and 5w30 has been known to shear to a 20 after a few thousand miles but may be less common with newer API oils) and therefore also has more "lubricating oil" in it.
I personally think that anyone who has a car spec'ed at an Xw-30 weight, it is beneficial to just put 10w-30 in during warm months but I'm sure there are scientific reasons why the manufacturers recommend a 5w-30 or a 0w-30. I know that PYB 10w-30 has great results for people with higher mileage cars, even those spec'ed for a 5w-20 weight.
1994 Explorer 4.0 - 250K mi
Out: O'Reilly's conventional 5W30 and MicroGard oil filter with around 3500 miles on it.
In: O'Reilly's conventional 10W40 high mileage and Wix oil filter.
2002 Ranger 3.0 - 231K mi
Out: NAPA or O'Reilly's 5W30 synthetic high mileage, some Mobil 1 top off, Wix filter, probably 8000 miles but there was top off.
In: O'Reilly's 5W30 synthetic high mileage, Wix filter.
Need to do the other Ranger but it's really nasty outside.
2003 avalanche 173k
Out
Mobil 1 /ac delco classic filter
In
Penzoil ultra platinum & purolator 1 filter in
2015 Chrysler 200 - 2.4l Multi-air
Out: Pennzoil Platinum 0w20
Mopar Mo-339 oil filter
In: Pennzoil Platinum 0w20
Fram ultra guard XG10060
2018 Silverado Z71 LT2 Crew Cab with 5.3 42248 miles.
Out 8 quarts STHM with AC Delco E-CORE
In 8 quarts Valvoline Full Synthetic with Maxlife Technology and WIX Filter.
1971 Chevrolet Chevelle
Engine: 496ci BBC (approximately 700hp)
158217 miles (on the vehicle)
Out: Penn Grade 1 15w40 and Wix 51061
In: Penn Grade 1 15w40 and Wix 51061
Friend of my real dads 1992 Ford F-150, in line 6 cylinder 2wheel drive. 200,xxx miles on truck.
Out: Rural King all fleet 10w30 HDEO and a MC filter
In: Rural King 15w40 and a Tough Guard filter
2008 2.4L Chev Malibu
Out: Pennzoil Platinum 5W-30 and TG 9018 filter off.
In: Pennzoil Ultra Platinum 5W-30 and TG 9018 on.
Only 5000 km's on the used oil but a mechanic at where my son did his co-op said frequent oil changes are imperative with this engine so my son ate that up.
30% was remaining and I told my son he could easily do 2 OLM revolutions using this oil and filter combo. Of course, dad knows nothing and this Midas mechanic knows it all.
Took the car to the dealership for a TSB. They changed the oil with their bulk when i made no such request. The Service Writer i usually go to apologized and they gave me new engine and cabin air filters. I wasn't that upset since these guys have always been great. Since they don't know what brand the bulk is ( only that its a blend), when i got home....
Originally Posted by ka9mnx
Funny how people with good intentions think they are doing you a favor...
Yes, and they really are good guys. They know I'm not one to take advantage of a situation. But as a company, i guess they have to make sure some manner of compensation was extended.
