Post your latest oil change
2016 VW Jetta w/1.4L turbo engine at 30,982 miles.
OUT: Castrol Magnatec 5W-30 Synthetic and a FRAM Extra Guard PH3614 oil filter
IN: Carquest Full Synthetic 5W-30 and a Carquest Premium #85348 oil filter
Are you aware that neither oil is appropriate for your Jetta?
I thought it would be, too. But, I've taken this Jetta to the dealer for oil changes since I purchased it. When I checked the invoice at the first change, it had Castrol 5-30 put in it. When I inquired about it, the service manager said 5-30 was just fine for the climate I live in, and the difference from 5-40 was negligible. They only put 5-40 in if the customer asks for it. It's had both 5-40 and 5-30 in it, with no difference in engine noise or driving ability.
They were most likely using Castrol Edge Professional OE 5W-30, which is a 502.00 approved oil:
https://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/711A4665F31054FE80257F8E006CA9C9/$File/BPXE-A9VF45.pdf
There are many different varies of 5W-30 oils; they can be extremely different.
What grade they use is almost irrelevant as long as they're putting in oil with the right VW specification. The only time it would make a difference is if you are routinely starting the car at extremely cold temperatures, below -25° F. Otherwise, if they are focusing on grade rather than specification you need to find a different mechanic.
Ah, thank you for the info. My sister has the Jetta, currently. She took it to her mechanic friend who did the work.
2012 Mazda 3 Skyactive - Chevron Conventional 5w30 - Basic Purolator oil filter
2008 Dodge Durango 4.7 - Chevron 5w30 Conventional - Super Tech oil filter
Out = same as above
2011 Hyundai Sonata
Out: 3 qts unknown + Fram OC
In: Supertech Syn HM + Supertech filter
2008 Corolla
Out: unknown + unknown paper element
In: Supertech 0w20 Syn HM + Fram Ultra
2005 Corvette Z-51 64,500 miles. OLM 72 percent. I had some cold starts over the winter just to keep it lubricated and thought it would be nice to change it. Mobil 1 10w30 and kept the old K&N oil filter on because of low mileage on the filter. Bought this car with 1000 miles back in 2005.
Vehicle: 2017 Subaru Impreza 2.0L 20K on unit/5K oci
Out: 4.2 Quarts QSUD 0W20 and Wix 57055 filter
In: 4.2 Quarts Castrol Magnatec 0W-20 and NAPA Gold 7055 filter
[Linked Image]
03 f150
5.4 v8
Out: unknown, Napa proselect filter
In: Napa 5/20, Napa gold filter
16 Jetta sportwagen
? 2.0 turbo 4 banger?, Wasn't paying attention to that
Out: unknown, probably a Napa gold filter
In: Napa syn dexos 5/30, Napa gold filter
Yes, im aware the oil isn't correct. I've made mention of it before and it falls on deaf ears. Not my call.
10 Tahoe
5.3 v8
Out: havoline 5/30, mighty filter
In: Napa 5/30, slick 50 restore, Napa gold filter
2017 Elantra Eco - Odometer 57,634
30 day/6,148 mile OCI
Out - 5W-30 Pennzoil Ultra Platinum, Fram XG9688
In - 5W-30 Mobil 1 Extended Performance, Fram XG9688
SMH. Bought two 5QT jugs of PUP, used one on my last oil change and one for the wife's car, and didn't remember to order more before I blew through this OCI, so had to go to Mobil 1 again.
Starting to consider just switching to Mobil 1 permanently. Especially since the price dropped to $25
Take a cross-country tour for those 30 days? What kind of trip gas mileage on your Eco? How much oil did the Elantra consume?
I do a lot of back and forth between Houston/San Antonio/Dallas. Been super busy as of late.
Mileage is usually high 30's when mostly highway driving. Lately I'm getting almost 40 MPG - and that's doing 80 MPH.
Oil consumption/dilution hasn't ever been an issue. 🤷â€â™‚ï¸
