Post your latest oil change
Oil change today.
Out: Pennzoil Platinum 5w-20 with only 3,682 miles on the oil
Mobil 1- m1-210 oil filter
In: Pennzoil Platinum 5w-20
Mopar - mo-899 oil filter
My truck does a lot of short trips, 5 miles to work and 5 miles back. It's taken on a good run from time to time but not as much as I would like. My wife's car is our driver on the weekend and she commutes 25 highway miles to and from her job, so the miles get put on her car. My truck is 7 years old and has 35,000 miles on it.
I decided long ago to just run a good synthetic to handle the affects of short trips and change it out in November and May. Basically, I do an oil change to run through winter and then again to run through summer.
2015 Dodge Durango 3.6L w/ 49k
Out: Pennzoil Platinum 5w-20 w/OEM filter
In: Pennzoil Platinum 5w-20 w/OEM filter
Oil had 8,584 miles on it. The OLM showed 12% left. I usually change around 7,500 but was late this time.
2007 Honda Accord
608,525 miles
Approx 4,500 miles on oil change.
Out: Havoline High Mileage 5w-20 + 2 or 3 quarts of top off of random oils, Purolator Synthetic PSL14610
In: Havoline High Mileage 5w-20, Fram Tough Guard TG7317
1999 BMW 323i 172k miles
Royal Purple HPS 10W40, Hengst oil filter
oil filter 18 ft lbs, drain plug 19 ft lbs
2001 Ranger 3.0 Vulcan, 166k miles
ST HM 10W30, Fram XG3600
drain plug 120 inch lbs
2016 Mitsubishi Outlander 2.4
ST Dexos 5W30, Napa Gold 1356
drain plug 29 ft lbs
1997 Honda Accord EX Wagon - 2.2 F22B1 4cyl
Mileage on vehicle - 218,610
OCI - 4 months and 4,233 miles
Out - 4.5 qts of Havoline High Mileage 10W-30 , Fram Extra Guard PH3593A
In - 4.5 qts of Havoline Pro DS 10W-30 , Fram Tough Guard TG7317
2010 Hyundai Elantra
6 month / 6K mile OCI
Out : PP5W30 D1 / Gen 2 ; Hyundai OEM Filter
In : PP5W30 D1 / Gen 2 ; Fram Ultra
2017 Hyundai Sonata 2.4L GDI
5 month / 5K mile OCI
Out : Castrol Edge 5W30 D1 / Gen 2 ; Fram Ultra
2017 Honda CRV, 30,306 miles.
Out: Mobil 1 EP 0W-20 - 1,846 miles.
In: Mobil 1 EP 0W-20.
Note: oil change only, no filter replacement. 3.4 quarts.
I re-flashed the vehicle with the latest PGM-FI and CVT calibrations. The service procedure calls for resetting the Maintenance Minder to 100% and replacing the engine oil only - so that is what I did.
Originally Posted by parshisa
Has this re-flash been done under oil dilution recall?
Technically it is a product-update, not a recall. But CA is not on the list of states that will be receiving the product-update.
I own the hardware needed to perform the reflash, so I just did it myself. I will make a post about it this week.
2011 Toyota Tacoma 4.0L 112,000
6,500 mi OCI
Switching up from Mobil 1 (Pennzoil seems to be on-sale more often).
Pennzoil Platinum 5W30
OEM Filter
07 Silverado
5.3 v8
Out: unknown, Napa gold filter
In: acdelco 5/30, full throttle hm oil treatment, Napa gold filter
00 impala
3.4 v6
In: acdelco 5/30, Napa gold filter
96 Chevy 1500
4.3 v6
Out: unknown, Napa proselect filter
In: motorcraft 10/30, Napa proselect filter
02 Chevy express 3500
5.7 v8
In: acdelco 5/30, Napa proselect filter
6,500 mi OCI
OEM Filter
Walmart seems to have Mobil 1 on Rollback almost daily. But Pennzoil has had some good deals lately.
2017 Subaru Crosstrek Limited, 12000 miles on car, 6000 on oil
Out: Dealer bulk Mobil 1 0w20, Subaru filter
In: Quaker State Ultimate Durability 0w20, Wix 57055 filter
I see what you did there.
Question. How vital do you consider the value priced M1 EP,,with its high PAO content, to the success of your maintenance plan ?
I am wondering if, say, econo Milesyn 0w20 in the 5 gallon tub or econo Super Tech Synthetic 0W20 in the 5 quart jug would produce ok results.
How big of a role does base stock play vs fuel dilution problems (and LSPI) ?
TY.
