Post your latest oil change
My friend's 2007 Crown Vic P71 with about... 190k miles? Gauge cluster is swapped so idk. Gosh I miss mine, can't wait til I get a truck to replace the hole in my life from it LOL.
Anyway, out came what I believe a mixture of Chevron Supreme and Castrol Magnatec with a MicroGard filter. We were aiming for 7K but I have a feeling it was just a liiiiiiittle bit beyond that.
In went some random mix of oil that I keep in 5 gallon buckets that consists of various leftover oils and another MicroGard filter.
And yes I'll be doing a cut and post of the filter from today's oil change, maybe tomorrow.
2016 GMC 2500 6.0L; out whatever Kal Tire put in & Wix xxx60 filter.
In; 0W40 M-1 Euro blend and the longer 6.2 filter (Delco).
29,500 kms/3950 hours!!! (company truck)
Why on earth would anybody need a 0W anything?
This truck could end up in Churchill, Manitoba or Hay River, NT
But, not with me in it.
edit.. 75w90 in both ends
The ladys 2014 jeep wrangler
3.6L v6 pentastar
~6k miles OCI
OUT: pennzoil platinum full syn 5w30
Premium Guard extended life filter
IN: Quaker State Full syn 5w30
Denso First Time fit filter
2012 Town and Country, 4500 on oil. 101,400 on vehicle.
Out, MS5k 5w20 and M1 15w50 blended to a 10w30, SuperTech cartridge filter.
In Maxlife 5w20 and Nexgen 10w40 blended to a 10w30 and SuperTech cartridge.
Why blend you'll ask? Can't pass up 1.00 a quart oils. The Widman calculator is my friend.
This change was 7.00 including the filter WM closed out when they switched to the new vendor.
1995 Pathfinder 3.0
Out: 5w30 pennzoil conventional and TG3682
In: 0w40 Castrol and QS3682
It was a spur of the moment oil change and this motor really only has 60k miles on it. But the valve stem seals appear to leak (noticed blue smoke on a cold start after a week), so hopefully won't cause any issues going to the castrol that was meant for my VW lol.
Changed the oil in the Corvette today (this is it's third oil change)
Out: M1 ESP Formula 5w30 and a Fram Ultra filter, both had 5578 miles on them (total on the car is now 8719 miles)
In: M1 ESP Formula 5w30 and a NAPA Gold 100290 filter (this is their new filter with the proper 22psi bypass)
Oil life monitor was at 25% and my average MPG for this interval was 25.6 MPG, with an average speed of 34 MPH
2018 KIA Sportage 2.4L LX AWD
Out: Mobil Super Synthetic 10W30
In: Pennzoil High Mileage 5W20
Out/In: OEM filter.
First Oil Change on factory new vehicle @ 2800 miles. Wanted to get the factory oil and all the break-in particles out before winter.
Plan to do next oil change and first UOA when this oil has 6,000 miles.
The filter cut-open pictures can be seen here: https://www.bobistheoilguy.com/foru...4-302b-cut-open-factory-part#Post4898859
2018 Mazda 3. Touring Hatchback
2.5L. Automatic Trans
Out: Factory oil
In: Milesyn 0w20, Fram 6607 Ultra Guard
Running low on oil reserves. 5 vehicles in the family and all have been using this Milesyn oil for the last 4 years or so along with Fram and Wix oil filters. Depending on the vehicle, typical OCI is 5000 to 6500 miles. I go thru almost two, 5-gallon pails of this every year. I've never done UOA before but will start this year and try to extend the intervals a little.
Ray
2002 Pontiac Grandam 3.4
Supertech 3980 (white) filter off and I can't remember what oil was put in it, I think it might have been Super S 5w30 synblend
Purolator L24011 filter on with 5 quarts of National 5w30
2002 F150 S-crew 5.4 liter
Supertech ST2 (white) filter off and Durablend 10w30 out
New ST2 (white) put on, put in Citgo Supergard Synthetic blend 5w30
Changed the oil in my mother-in-law's car.
2002 Buick LeSabre
3.8L V6, 109k miles
Out: Jiffy Lube Special 10w-30
In: Pennzoil conventional 10w-30 with a Napa Gold 1040 filter
06 Cadillac Escalade Ext, 5k miles on oil, 190k miles on truck.
Out: frankenbrew 10/30, ST clearance oil filter
In: PYB 5w30, ST clearance oil filter
My stash is now down to 1 qt of magnatec 10w30
GM / Holden / Opel Astra (AH)
OCI = 10,150 km / 6,300 miles / 8 months
Out: Penrite Vantage 10W40 A3/B4 semi-synthetic
In: Castrol GTX Ultraclean 15W40 A3/B3 semi-synthetic
Same Wesfil-Cooper Z154 filter
2015 Ford C-Max SE (hybrid) with a 2.0L port injected
Eneos Racing Street 0w-20
oversized Fram Ultra XG3600 oil filter
--- out went the normal-sized Microgreen oil filter
--- oil chosen due to it having SN GF-5 ratings and the lowest winter KV40 viscosity I could find, with spec HTHS 2.7, and 900 ppm moly for start-stop hybrid operation.
Later today, the 4Runner will lose the Amsoil OE 5w-20/Wix combo after ~7200 miles and will get 6-1/2 quarts of OE 5w-30 and another Wix, UOAs to be compared.
