Post your latest oil change
2006 Toyota Sienna LE V6 (3MZFE) 5-speed automatic
109,xxx miles
5,000 mile OCI
No makeup oil
Out:
Pennzoil 5w-30
Purolator Classic
In:
Valvoline Premium 5w-30
Fram ToughGuard
Rotated the tires and changed the engine air filter too!
1998 Chevy Cavalier with about 105,000 miles on it.
Out: Peak 5W-30, Purolator Classic filter
In: Havoline 5W-30, Super Tech filter I found in my stash
Changing filter in this car is a semi-pain cuz I have to remove front right wheel to get to the oil filter.
Friends 01 Saturn LS out: Kendall syn blend and firestone E-core with 7500 miles on it. In: Havoline 5w30 with Napa Silver filter
2008 CRV, 127k
Out: QS 5-20 and NAPA Pro-Select
In: 5 qt Valvoline Maxlife 5w-20, NAPA Gold filter.
Also did an ATF drain/refill (due per Maint Minder), inspection, tire rotation, coolant replacement, new drive belt, brake flush and new battery.
2010 Chrysler Sebring
25,173 miles on car, 4200 miles on oil
Out-Valvoline Nextgen 5w30 and STP oil filter
In- Valvoline Nextgen 5w30 and Microguard filter
Going for a 4k mile OCI
2013 Fiat 500 Sport (Mine) 16,338 miles
Out PU 5W30 SM OEM Filter
In PU 5W30 SN OEM Filter
8004 miles on oil. factory calls for 6mo/8K interval.
Her Fiat 500 gets done later today.
2009 Ford Fusion 69K on it
Out: mix of valvoline durablend and castrol synblend 5w-20
In: PU 5w-20
Always use Motorcraft filters.
2008 Chrysler Town & Country 3.3L V6
68,106
out:
? Synthetic Blend 5w20 (whatever brand the local Midas uses)
Napa Proselect filter
4040 miles and about 10 months on oil/filter
in:
5 qts Castrol GTX Synthetic Blend 5w20
Wix 51348 filter
comments... either the 7 quart drain pan i have isn't 7 quarts or they overfilled my mom's van at midas... going by the little markings on the inside of the pan not counting what came out of the filter it was probably 6.5 quarts and on top of that the head of her drain plug was rounded off making it not so easy to remove and required me to go get a replacement
i kinda want to call midas and let them know i'm not happy
1998 BMW 328is (M52) @ 118,815 miles
Out: BMW 5w-30 Full Synthetic and OEM Mann filter 5232 miles/10.5 months on oil. It still had 3 bars left, but there were a lot of short trips this winter and some time spent in a body shop (lots of short runs moving it around).
In: 6.7 qts of Mobil 1 0w-40 (SN) and another OEM filter.
2008 Infiniti G37 - forgot my mileage book in the garage
Out - PYB 5w-30 SN/GF-5 and Hastings LF240
In - Mobil Delvac 1 ESP 5w-40 CJ-4/SM and Wix 51356
OVERKILL switched to PU, so I did this to restore balance to the oil universe.
HAHAHAHHA!!! Well done sir!
2010 Mistubishi Lancer Ralliart Sportback
OUT: Castrol gold EDGE 10w30
IN: Castrol EDGE FST 10w30
I also took the time to cross rotate the tires for maximum tire life.
