Post your latest oil change
1998 F150 V6 - Seemed like only yesterday (March 16th) when I hit 280,000 miles.
Out:
Quaker State Ultimate Durability 5W30 with Purolator Gold Filter - I actually ran this a few minutes short of 10,000 with only one quart makeup oil required.
In:
Valvoline Synpower 5W20 with Wix Filter - I had this laying around. Actual change mileage was 289,614 and I anticipate running this until 300,000 before I change it again.
_______________________
Grandmas car yesterday, '08 Accord, Pennzoil Conventional 5w20 and an OEM Honda filter. change at OLM 30%
Uncles Kia Sorento today, 2011, Mobil 1 5W20 and a Kia filter. Every 6k.
I should update...
Toyota Prius, 138,800 miles -
OUT : Mobil Super Synthetic 5w20 with Peak Syn 5w20, Puro Classic
IN : Havoline Deposit Shield 5w20 conventional, Puro Classic
Hyundai, 80,653 miles -
Originally had changed from Mobil Super 5000 to Castrol Syntec 5w50 but decided it was too heavy for my use.
So,
OUT : Castrol Syntec 5w50 @ 12 miles, stored into Max Life bottles and labeled
IN : Valvoline MaxLife Synthetic, P1 filter
2004 Chevy Venture 136k
Out: Rotella T5 w/ Pennzoil Platinum 5w20 blend
In: Rotella conventional 10w30 w/ .5 quart MMO.
Oversize Puro Classic filter
My 2011 Civic:
Out at 68K KMs
4 qts Mobil 1 5w20 SN - 10,300 KM OCI
PureONE filter
In:
4 qts Nextgen conventional 5w20 - Will probably be 8000KM OCI.
PureONE filter
My folks' 2000 Maxima
Out at 193,000KM
4 qts Pennzoil Platinum 5w30
Napa Gold 1356
In:
4 qts Mobil Super 2000 10w30
PureONE filter
1989 BMW 535i/5 speed 159,855
In: Pennzoil conventional 10w-40 / NAPA Gold Filter
Out: Supertech 5w30 Syn / Mahle Filter (2100 miles)
05 ford focus 60,000 miles
05 ford escape 79,000 miles
another 05 ford focus. 92,000 miles
All three received 1.5 qts. Pennzoil conventional, and the remaining 3 or so qts of Penz. Ultra. All 5-20 weight. Motorcraft oil filters.
Previous oil used exclusively was MC 5-20.
2007 Mazdaspeed 3
Out: Mobil 1 5w30 and OEM Mazda filter
In: Mobil 1 5w30 and OEM Mazda filter
2009 328i
Out: BMW 5w30 and OEM BMW filter
In: Mobil 1 0W-40 and OEM BMW filter
2006 Scion tC, 100k miles. Used Pennzoil conventional - first time since the break-in oil.
5w30, Pure1 filter.
Just seeing how it holds up after 99k miles of expensive synth!
So far, it hasn't died on me
2010 Subaru Legacy 2.5 NA
45K on the clock/7500 OCI
Out: Quaker State Ultimate Durability 5w30 and Purolator P1 PL14612
In: Quaker State Ultimate Durability 5w30 and Purolator P1 PL14612
Firm believer in "if it isn't broke don't fix it."
Back on 7/4/12...
OUT: Pennzoil Ultra 5w30 w/ Royal Purple 10-2808 oil filter [7,500 miles; coolant present in subsequent UOA]
IN: Valvoline "WB" 5w30 w/ Bosch D+3323(leaked) and replaced with ML 1002 + LUBEGARD® BIO-TECH Engine Oil Protectant
Yesterday, in the Focus:
Out: 4.5 qts Peak conventional 5w30 + a smidge of leftover MoS2, Fram TG oil filter... Mileage in service: ~ 5,180 miles.
In: 4.5 qts Havoline conventional 5w-20, Pennzoil oil filter... Mileage planned: ~5,000 miles.
1 week and a half ago. Mobil 1 Turbo Diesel Truck 5w40 with Wix filters in my '04 cavalier. noticed a little oil consumption every 3000-4000 miles thought id give it a try. I Have ran 5w30, 10w30, SAE30 oils in Mobil 1 5w30 10-30, Mobil 1-HM 5-30 10-30, Royal Purple 5-30,10-30 Kendall 30WT, Royal Purple SAE30, Pennzoil Platnium 5-30 and 10-30, Rotella T6 10-30, now Mobil 1 Turbo Diesel Truck 5w40.
Ive read that these ecotecs are oil burners so hopefully the Mobil 1 Turbo Diesel Truck does the trick if not Amsoil will be the next step.
For some reason I believe oil is splashing under the pistons and burning off so if the Mobil 1 Turbo Diesel Truck is good enough to run through a nice hot turbo I hope it would with stand the heat from under the pistons.
2006 Lincoln Mark LT
8,200 miles on oil
Out: 7 quarts Amsoil S.S. 0W-20 and Amsoil EA011 oil filter
In: 7 quarts Quaker State 0W-20 and Purolator PL24651 oil filter
