Post your latest oil change
2001 Jeep Cherokee 4,000 miles out unknown oil that I forgot I used and Napa filter
In: 5qts Supertech High Mileage 10w40 and 1 qt leftover 15w40 Delvac and Mobil 1 filter
'95 Toyota Celica GT (5SFE)
124k miles
Formula Shell 5w30
Pure One filter
This is replacing unknown oil and an ocod.
(First oil change since we bought it in July).
Today
07 Kia Optima 103725
Out:
Valvoline 5w20 conventional
Napa Gold Oil Filter
In:
Valvoline NextGen 5w-20
Purolator PureOne
2004 BMW X3 2.5
M54 I6
123,838 miles
7 quarts Mobil 1 Turbo Diesel Truck 5w40
BMW PN 11427512300 filter
My daughter's 2002 Nissan Sentra 1.8
2.8 qts. Pennzoil Synthetic 5w30
PureOne filter
She bought the Sentra over the summer, and this was the first opportunity I had to do the oil change. If I find whoever did the previous change, I will wreak vengeance upon them and their children's children. I have never run-across a drain bolt so utterly frozen in-place. After finally getting it off, I examined it and discovered that there were two copper crush washers on the bolt, and they had been flattened paper-thin and practically fused together. It took me a long time to wrestle them off the bolt.
I'm used to the ease of oil changes on our Maxima, so I wasn't prepared for the filter location on the Sentra. Way in back and up on the block, requiring you to fit your hand up and around a support beam and the catalytic converter. This immediately told me that there would be no way to avoid an arm-full of oil, once the filter was loosened. But, that would take awhile, since the filter was on almost as tight as the drain bolt was. Obviously, the previous mechanic had never heard of "finger tight".
I eventually got it off (and got an arm-full of oil, as I expected). I was surprised that the Sentra 1.8 takes only 2.8qts of oil. The 1.8 in my GTi takes 4.2qts.
Anyway, it's on the road, and my back hurts badly.
2007 Ford Mustang, brother's car;
-5qts Pennzoil Platinum 5w30
-MC FL-820S filter
9,000 miles on last fill of Pennzoil Platinum, 56,500 total miles.
2010 Ford Fusion 2.5
5.2qt Quaker State UD Syn 0w20
Purolator Pure 1 Filter
2002 Chevy Cavalier 2.2ohv
4qts Mobil 1 10w30
Changed the oil on my '04 Colorado today.
112,500 miles
Previous oil was 5 qts. Mobil 1 Advanced Fuel Economy 0w30 and 1 qt. Mobil 1 High Mileage 5w30 along with a P1 filter. It was run for 7,500 miles between April 28th & today, October 30th.
Today, I put in 5 qts. Mobil 1 Advanced Fuel Economy 0w30 and 1 qt. of Toyota 0w20 along with a P1 filter. I used the Toyota 0w20 since I thought the light viscosity would help just a tad more throughout the winter.
2003 Mazda Tribute LX V-6, 118,566 miles.
Out: Valvoline 5w20 conventional + Fram Oil Treatment + MPH2 filter.
5,575 miles on OCI, sample sent for UOA.
In: Quaker State Conventional 5w20 + MPH2 filter
2001 Mazda 626 V6 110,500 miles
Out: Quaker State Conventional 10w30, OEM Mazda Filter
Miles on oil 3,500
In: Quaker State Conventional 10w30, Fram Filter (Orange)
2009 Nissan Altima 2.5L QR25DE
Out: Peak 5w30 SN / Purolator L14612
Miles on oil: 9586 (I hope this is wrong; perhaps I wrote down the incorrect mileage last OCI?)
In: 1 gal. Pennzoil Conventional SM 5w30 & 1 quart Mobil 1 10w30 (K-Mart/TSC clearance) / Purolator PL14610
This is my buddy's car. This is the second time he's gone 9k+ on one dino OCI... the old oil was black and it doesn't look too good through the fill hole. This was an ex-rental car. The hubcabs on the rims look like they're about to fall off, his tires are perpetually low, the oil is never serviced except when I almost force him to accept an oil change, and with the way he drives he absolutely needs new brakes by now - I've had to top off his brake fluid reservoir twice now because the level lowers noticeably, and one or more of his disc brakes are squealing.
That's not all. The interior reeks and is dirty (he's a smoker), the A/C condenser is bent at an angle (i.e. not parallel with the engine), and the coolant and power steering were overfull (I corrected the PSF with some house brand PSF I got for $2/qt).
Last time I changed his oil was on 2011-05-30 at 28,864 miles. I set the service reminder to beep at 3,750 miles. He obviously reset it once.
He doesn't care about his car, I'm not sure why I still care.
Watch out, because on those Altimas the reason for low brake fluid is due to the master cylinder leaking.
