Post your latest oil change
2003 Chevy TrailBlazer
7 qts. Castrol GTX 5w-30
ACDelco Duraguard filter
OLM was down to 8% after ~13,000 miles this go round.
'01 Jeep Grand Cherokee 4.0L - Maxlife 10w30 & Pro-tec filter (made by WIX) - drained Pennzoil HM w/ 4500k on it
'98 Jeep Grand Cherokee 5.9L - M1 HM Formula 10w30 & Pro-tec filter - drained M1 HM also w/ about 4k on it
Just got back from Wal Mart and picked up a 5 qt jug of Maxlife 5w-20 and Super Tech ST7317 oil filter and about to do it tomorrow.
I got almost 7000 miles on the current Maxlife OCI which is the first with this oil. I am anxious to change it out for this reason alone not to mention how this oil will do in OCI #2. I am a firm believer is using the same oil until either your cars needs change or you find a better oil.
Get ready...
Have you used the Mobil Hm oil in your Cherokee before this? Did it seem like it was dirty/cleaned well compared to other oil at 4k miles? Thanks
2006 Lexus RX400h (hybrid)
5 litres of Pennzoil Platinum 5w30
Fram synthetic filter (Xtended Guard) because they were on sale
Next oil change will be 5w20 since Toyota has a TSB out that it's OK to use a 20 weight in this engine.
I have used M1 HM in this particular Jeep since it had about 150k on it right after M1 HM first hit the Wal-Mart shelves...The Jeep now has 179k on it, but has been retired as a DD since a year ago. I have gone 3-4k OCI on M1 since I bought the Jeep with 65k on it in 2001. The only thing I can say for sure between the regular M1 vs the HM formula is that they seemed to darken about the same rate, but the standard M1 seems to burn off faster a little bit. I honestly can't say for sure the answer top your question but I would imagine that if you chose a full-syn oil for an older motor, then I'd definitely use a HM formula...if it was me I would use a HM dino oil like Pennzoil or Maxlife in that truck.
Gf`s 1998 Olds 88........143,000 miles,Valvoline wb 10W30/AC Delco filter every 3000k.
2009 Jeep Librty 3.7L
NAPA Synthetic 5w-20
Fram Xtended Guard....filters tough to find.
PIA to change filter!
1996 Chevrolet Impala SS
Valvoline SynPower 5w30
AC Delco PF 52 Filter
2003 Ford Explorer
Motorcraft Syn Blend 5w20
Motorcraft FL-820S Filter
03' Corolla- Schaeffer 7000 10w30, Supertech Filter.
Haven't done the Vic yet, probably will do ARX first, then Schaeffer's or PP.
