Post your latest oil change
Originally Posted By: heavychevy96
'04 PT Cruiser
5qts. 5w30PP, Napa Gold 1348
97K miles
Good combo, +1!
2010 Hyundai Santa Fe GL 3.5 V6:
PYB SM 5W-20 3 liters / PYB SM 5W-30 2.2 liters
Hyundai/Mahle OX 417 cartridge filter $11.US or $17.62 Can
Driving to Florida this week-end...
1994 Dodge Intrepid 3.3L ES with 254K
Out - No idea what oil / ph16 filter.
In - 1 qt random oil, 1 qt Duralube (Dad gave it to me, figured I'd use it up), 2 qts 10w30 PYB, 1 qt 10w30 Halvoline / fram ph16 filter.
Wanted to use up some random oils I had laying around... plan on running this concoction for 5.5K miles. Would have used QS filters however they didn't have the right filter so I went with a Fram (this time... next time more than likely supertech.)
2001 Taurus base model engine (3.0L "Vulcan"?)
Mobil Super High Mileage 5w30, Motorcraft filter.
500mi since oil change. Consumption cut to half of what it was (or less).
No more stink of burning oil immediately after startup (from leaky valve stems).
2002 Cavalier 2.2ohv 4qts Mobil Special Synthetic 5w30
Advance Auto Red Grip (Purolator) Filter
2010 Ford Fusion 2.5 dohc 5.3qts Mobil 1 0w20 AFE Synthetic
Purolator Pure 1 Filter
Did two on Saturday.
2004 Cadillac Deville (my dad's)
7 qts. Mobil 1 HM 5w-30
AC PF61 filter
1997 Jeep TJ 2.5L
4 qts. Rotella T5 10w-30
Wix filter
2008 YARIS sedan :
In: SHELL full synthetic 5w-30 (SN/GF-5) w/ TOYO(Denso) oil filter
Out: P.Y.B. 5w-30 (SN/GF-5) w/ TOYO (Denso) oil filter , 4,510 mis. on oil .
Sent sample in for analysis due to head gasket replacement at 23,747 miles , now has 30,945 at time of O.C.. This was the 3rd O.C. since the repair under warranty . The tech used excessive amount of the TOYOTA black silicone form in place gasket sealant . It's all over the engine block . Makes us wonder how much was /is inside the engine . There were many small pieces in the bottom of the bucket used to drain the oil into . May try to take the TOYOTA 90915-YZZF2 apart to see what it captured . The car also seems to be loosing coolant since the replacement . May be able to post the U.O.A. by Friday the 13th
. Hopefully all will be good .
2001 Kia Sportage
Peak 5w30
Purolator PureOne
2008 Mazda 3
Peak 5w20 Synthetic
Purolator PureOne
First time changing my oil. Last oil change place that touched my Mazda wrenched the drain plug and filter on so tight I had to get a breaker bar and filter wrench. Extra expenses that I didn't initially account for.
