Post your latest oil change
2003 Pontiac Vibe GT, high-revving 1.8L VVTL-i, 127,950 miles.
Out: Shell Rotella T6 5W-40 + PP 5W-30 + Valvoline VR1 10W-30 brew, Purolator Tech filter; 4,750 miles on oil.
In: Amazon Basics Euro 0W-40 (3.6qt) + QS Ultimate Durability API SM 0W-20 (1qt).
1327/1242 PPM Zinc/Phosphorus in AB 0W-40 for the high cam lobes! The 2011 vintage QSUD is to slightly thin the brew. No sediment in clear bottle after 13 years!
That's the same oil I use in the Kia.
I am almost at 3k of the OCI. No consumption , so 5 Stars there.
But the same sewing machine engine sound as the QS Euro 5w40 this past summer..... so only 3 Stars there.
I'm putting the Amsoil Euro 0w30 in the Hyundai next and will try the Castrol Euro 5w40 in the Kia sewing machine this spring.
(y)
I run Amsoil in just about everything.Boat, SxS, mower, you name it.
Friends 21’ Ram 1500 Laramie truck.
7,xxx on Pennzoil Platinum 5w20. Filter was PZ made in China one.
In: some Castrol Edge EP 5w20 and a WIX 57060 made in USA. HE HAS 43k on truck, not a lot of short trips, works from home.
Just finished up my Priest's 2023 Subaru Crosstrek, 31k on odometer. Out PZL 0/20 and Subaru filter and in with PZL 0/20 and Subaru oil filter, and changed rear differential oil with Valvoline 75/90. I do all the maintenance on his vehicle. Next weekend front diff oil change when I pick up the washers for the plugs. Changes every 5-6k miles. Saves him a few bucks. Getting older at 68 harder to get on the ground:)
Changed the oil on my maverick
Out:
Pennzoil Ultra Platinum 5w30
Motorcraft FL910S
2450 miles on oil and filter
In:
Motorcraft FL910S
Will run this oil and filter 5,000 miles
Initially changed the oil at 2500 miles to get the factory fill out. Wanted to get on a 5,000 cycle. So changed it again today and rotated the tires for the first time
Pulled off double play today:
2022 Subie Crosstrek (daughter)
Out: Mobil 1 0-20 and Tokyo Roki filter
In: Mobil 1 0-20, Tokyo Roki filter and Valvomax
6 month changeout
2005 Honda Pilot (son)
Out: Mobil 1 Euro 5-40
In: Mobil 1 Euro 5-40
No filter change, did it last time. 6 month changeout also
2019 Ram 1500 Classic
Out: HPL Super Car 0w20 and a Mobil 1 filter. 11,956 miles and almost exactly 1 year on the oil (3/24/23 was last change). Fumoto valve made it almost painless, but the oil filter still sucks to do.
In: HPL Super Car 0w30 and a Fram Ultra filter.
Will be sending out a sample for analysis. And HPL threw 2 stickers into my order, which made not only my day but also my oldest sons day who insisted 1 be put on the garage door. The other I’ll put on my tool box at work. Thanks guys!
