Post Your Latest (Motorcycle) Oil Change!
That's a good question. Magnetic drain plug picks up particles that indicate something is drastically wrong. When it's a fine sludge and of such a small amount, that says the internal wear is doing well. Very similar to looking at a filter and seeing if it has metal particles in it. I haven't heard a magnetic plug changes the overall analysis.
In any case, my bike typically has higher aluminum due to clutch basket wear as it's over 91,000 Mi on the original clutch. That's what has been said by folks here on the forum.
Aluminum (clutch basket) won't show on the drain plug and there's no sign of it in the filter. Analysis is microscopic particles with respect to PPM of engine wear metals.
The bike doesn't burn a drop of oil over 5,000 Mi so there's no issue in my opinion with respect to pistons or engine internals.
I told you that bike is bulletproof
Also the clutch basket 150.000km is outstanding
Old Japan’s bikes is taxi 🚕 on reliability
It theoretically should decrease the PPM of ferrous metals in the UOA. If all of that debris on the magnetic drain plug was put back into the oil right before the oil was changed and sampled there would be more debris in the oil. And most of that on the drain plug is too small to be captured by the oil filter.
