1992 Chevrolet Silverado 1500
Freshly rebuilt 5.7 TBI V8
Replaced radiator and all hoses, flushed heater core prior to engine installation. Used shop water for engine Break in
Out: water
In: Shellzone conventional green premix
2000 Ford F-150
4.6 V8
Water pump replacement, flushed block, heater core and radiator
Out: unknown green coolant
In: Fram conventional green concentrate mixed 50/50 with distilled water
1967 Impala - Recored the radiator with HE tubes, new Gates hoses
Out - Unknown
In - Prestone® All Vehicles Antifreeze + Coolant Concentrate mixed to roughly 50/50
2009 Toyota Camry Hybrid
Replaced thermostat, Toyota P/N 90916-03136
Replaced lower radiator hose, Toyota P/N 16572-0H090
Replaced engine and inverter coolant with Toyota SLLC
Wife's M35 was done last month at about 124,000 miles. Coolant disposal was a problem for me so I had my local Indie shop do the flush along with the NC state inspection. They used BG radiator flush and Autozone universal coolant. This will be the last one needed on this vehicle.
Trying to get my 96 Ram CTD (4x4, 266k miles) from whatever was in there to JD Cool Gard II. I did this long ago on my other 96 (2wd, 445k miles).
It is a 26 quart system as I recall somIll be a while.
It’s so easy to just siphon out the radiator that Injust do that and swap with distilled, drive a bit, repeat. I can do it at the curb, totally clean. Sometimes opening a block drain is a good move, I may yet do that too. But to start getting distilled in there I’m rolling this way….
