Post Your Latest Coolant Change.
1992 Chevrolet Silverado 1500
Freshly rebuilt 5.7 TBI V8
Replaced radiator and all hoses, flushed heater core prior to engine installation. Used shop water for engine Break in
Out: water
In: Shellzone conventional green premix
2000 Ford F-150
4.6 V8
Water pump replacement, flushed block, heater core and radiator
Out: unknown green coolant
In: Fram conventional green concentrate mixed 50/50 with distilled water
1967 Impala - Recored the radiator with HE tubes, new Gates hoses
Out - Unknown
In - Prestone® All Vehicles Antifreeze + Coolant Concentrate mixed to roughly 50/50
2009 Toyota Camry Hybrid
Replaced thermostat, Toyota P/N 90916-03136
Replaced lower radiator hose, Toyota P/N 16572-0H090
Replaced engine and inverter coolant with Toyota SLLC
2013 Civic LX, 141K, 1st service AFAIK...
Out: Some blue Honda(?) stuff
In: 1+ gallon Zerex Aisian Blue
Gotta love those radiator fill funnels. Nuthin' to it. Squeeze the upper hose a little and put the funnel stopper in; you won't spill a drop.
2004 Chevrolet Tahoe
5.3 V8
Replaced radiator, upper and lower radiator hoses, flushed block and heater core
Out: unknown orange coolant
In: AcDelco Dexcool concentrate, distilled water 50/50
1989 GMC Sierra 2500
5.7 TBI V8
Replaced radiator, radiator hoses, thermostat, heater hoses, flushed block and heater core
In: Fram Conventional Green concentrate, distilled water 50/50
Wife's M35 was done last month at about 124,000 miles. Coolant disposal was a problem for me so I had my local Indie shop do the flush along with the NC state inspection. They used BG radiator flush and Autozone universal coolant. This will be the last one needed on this vehicle.
1966 Chevrolet C10 with LS motor & AFCO radiator. Prestone All Vehicles - 10 year/300k miles concentrat, 2 gallons
2015 Altima S strippie, ex-Hertz
160K; probably 1st service
Out: Blue stuff
In: About 5 to 6 quarts Aisin blue coolant; Supertech and Zerex
Trying to get my 96 Ram CTD (4x4, 266k miles) from whatever was in there to JD Cool Gard II. I did this long ago on my other 96 (2wd, 445k miles).
It is a 26 quart system as I recall somIll be a while.
It’s so easy to just siphon out the radiator that Injust do that and swap with distilled, drive a bit, repeat. I can do it at the curb, totally clean. Sometimes opening a block drain is a good move, I may yet do that too. But to start getting distilled in there I’m rolling this way….
Radiator looks good!
Zerex full concentrate, G05 and distilled water in my 2002 Ford F-150 FX4, 4.6 liter
2 valve extended cab pickum up truck.
