Someone should try driving a course by accelerating in 5th gear, and then costing a bit in neutral, then accelerate again. The engine would spend more time at full throttle, where thermal efficiency is higher.
BMW uses the valves to act as throttles to limit airflow, while diesels are still unthrottled. So you still have a fundamental difference in operation (limiting airflow vs. limiting fuel flow).quote:
Originally posted by yugrus:
quote:
Anyone interested in hearing more? if so, where might I start (the beginning)?I am, for sure. For one, I have a question about the volumetric efficiency difference between diesels and GDI (gasoline direct injection) engines. The later do not have butterfly valve (BMW), so their cycle are much more like diesels now, except for ignition and fuel/air management? Are they equivalent in efficiency? [/QB]
If you ever raced cars on the track you would be used to looking way ahead in traffic. My normal driving is to step on it hard to get going. But then I look 1/4 mile ahead to see if I should speed up or coast the 'rest of the way. I rarely use my brakes.quote:
