Off the wall -
1.) How about a check valve within the oil pump pick-up, just behind the screen? This would maintain the pumps prime during times of inoperation, minimizing delay in pressure build upon start-up.
2.) Has anyone tried applying ionization charges to fuel and air to posibly help with economy? How might these attractive forces play in the dynamics? Fuel negatively charged as is the engine block (thus representing repulisve effects, helping to keep fuel in suspension), the air positively charged (because of the opposit polar charge as fuel, it would present an attractive force between the two). Concerns I have are with self-discharge via spark...for obvious reasons. Turbulent flow in itself may present ionization processes, but I don't yet understand the effect(s).
The more I ponder the operating efficiencies between spark and compression ignition engines, the more I find in favor with compression ignition engines.
1.) Aside from leverage gains between crank and connection rod which is relative to a piston's stroke, a spark ignition engine at low throttle, is theoretically running as though it were a low compression engine - a partial vacuum exists upon completion of the intake cycle, leaving an overall lower compression pressure prior to ignition, unlike a compression ignition engine. This would relate to what is called the volumetric efficiency of the engine at that point.
It has been noted that an expected volumetric efficiency of an unmodified production engine is around 80%, meaning that at full-throttle, the intake charge is around 80% of the engine's actual displacement. Even though the mechanics of the engine have a defined compression ratio, the compression ratio of gases within the combustion chamber above atmospheric pressure is much less definable. Factors such as intake restrictions (butterfly, air cleaner, valves, etc.), air raming, valve actuation, exhaust scavenging, intake resonance, and turbo/super charging, can all have an effect on the engine's volumetric efficiency, even having it exceed 100% (raming, resonance, turbo/super charging). One may now understand how volumetric efficiency also varies with rpm, and start to see how compression ignition engines are less effected and more efficient.
I feel like I'm spilling my brains, needing to make an order before presenting all this.
Anyone interested in hearing more? if so, where might I start (the beginning)?
