I did a tune up on my Dakota yesterday. I used my existing wires, they are the Napa Belden Premium set and are only a couple years old. My plugs have metal heat shields on them and the wires have a long boot to reach down inside the heat shield. When I pulled the plug wires off a couple of my plugs, the wire boot was stuck on there pretty tight, even though I had used dielectric grease in the boots. I mean I had to yank on it hard to get it loose. I replaced the plugs with NGK copper core FRF-6's, used the better quality Napa cap and rotor, the Echlin brand with brass contacts.
Ever since I finished the tune up I have a very slight surge in the idle. It will idle at about 700 RPM, which is normal but every 10 seconds or so it will increase to about 800 RPM for a few seconds and then drop back down to 700 again. The odd thing is if I turn on the AC, the idle stays steady at 700 RPM.
I wonder if those 2 plug wires I had to pull so hard might have stretched the wires inside so now they don't make as good a connection? Can an engine still run OK or maybe run with a slight problem like a weird idle fluctuation with a couple plug wires that might be stretched like that?
I spent a long time looking and checking but I found no vacuum leaks, nothing knocked loose or anything like that. I have no trouble codes stored, CEL is not on. I have done probably half a dozen tune ups on my truck since I have owned it, never had this problem before. Truck ran perfectly fine before I did this tune up. It was not quite time for a tune up yet, I only did it because I had read online it is a good idea to do a tune up with new plugs after replacing a catalytic convertor, which I had done last week. Truck is running fine now, other than this odd idle problem.
I appreciate any help here. Sorry for the long post.
