I've got the tank out of the '47 Lincoln, and it's pretty rusty after 77 years. I could tell the stale gas had some water in it too, but it's safe to say it's probably never been emptied in 77 years. I've got some Evapo-rust working on the bottom of the tank where it's the worst, and it's cleaning up nicely. I've got some Rust911 concentrate on order to make up enough solution to mostly fill the tank. I had good luck with POR-15 on the motorcycle's gas tank, which was also pretty rusty but cleaned up well with vinegar. The Lincoln's tank, however, is much larger at 19 gallons, there's a baffle in the middle of the tank, and the fuel pickup tube is just hanging out in the middle. So, do I try POR-15 and coat most of the tank, or just clean up the rust as best I can and leave it as is?
