Originally Posted By: Vikas
Do Time Serts or Helicoil use non-stock spark plugs or existing spark plugs (I meant the one which survived the blowout
Is the concept similar to anti-fouler where the plug sits further out of the cylinder?
You don't want to use a Helicoil in this application, you want to use the insert. It replaces the threaded section with a new threaded section that has far more threads (12 IIRC) for the plug to thread into.
The Lock-N-Stitch kit has a lock pin that gets installed after the insert so the insert itself can never back out.
You use the original type of plug in these inserts, and they situate the plug in the exact same location they were originally. There is just a lot more holding them in now.
