My 2000 Chevy 454 v8 motorhome has an idle problem that shows up in in cold weather. On cold start the idle will not stablize but fluctuates between around 500-600 and around 1000. At the low end it will start to run rough, then speed up. Once speeded up it drops back until it starts running rough and repeats the cycle. This cycle probably takes only about 3 to 10 seconds. Once the engine gets to a certain level of warm, it idles fine. Idle on this motorhome is 600 rpm. It only happens in colder weather. I have experienced it in the 30s (F) and below, but not in warmer temps like 50s and up.
The motorhome has 15,500 miles and is a 2000, so it had sat a lot over the years, but otherwise runs great.
Is there any value to disconnecting the battery neg cable for a few minutes then reconnecting to reset the computer?
Seems like maybe that thing called an idle air control could be malfunctioning? If cheap and accessible I could throw a part at it and see if it works.
