Here is the GM service info. Does require a Tech 2 scan tool. Sorry you don't live near me or I'd do it for ya!
Service Information
2008 Pontiac G6 | G6 (VIN Z) Service Manual | Document ID: 1811499
Remote Control Door Lock Transmitter Programming
Important:
• Up to 4 transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle. The order in which the transmitters are programmed is important. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. Use care to program the transmitters correctly.
• The scan tool must stay connected until all of the transmitters are programmed.
• The keyless entry transmitters used in the Advance 2 Way Remote Start System isare unique to the system. When servicing or replacing a transmitter, ensure that the correct transmitter is used. The correct transmitter part number can be found in the Accessory section of the parts catalog. Attempting to replace an Advance 2 Way Remote Start transmitter with a regular service part will result in a failure to program the transmitter.
Invalidate All
This procedure will erase all keyless entry transmitters from memory.
Install a scan tool.
Turn ON the ignition with the engine OFF.
With the scan tool, select Body.
Select Remote Control Door Lock Receiver (RCDLR).
Select Module Setup.
Select Program Key Fobs.
Select Invalidate All.
Follow the scan tool on screen instructions.
Next Available Slot
Incremental programming allows for a transmitter to be programmed into the next available location without affecting the currently programmed transmitters. Previously programmed transmitters will not be erased during this procedure.
Important: If all 4 slots are programmed, the Invalidate All procedure will need to be performed to allow transmitter programming.
Select Next Available Slot.
Remove the scan tool.
Exit the vehicle. Operate all functions on transmitters to verify correct system operation.
Transmitter Slot Programming
Transmitter slot programming allows a single transmitter to be programmed into a specific slot without affecting any of the other programmed transmitters. By using slot programming, the transmitter originally programmed to a specific slot is erased and the new transmitter learned in its placed.
Select the key fob desired to be programmed.
© 2009 General Motors Corporation. All rights reserved.
