I've had good results using Amsoil in my Pontiac 455. Its a high performance engine and uses fast bleed Rhoads lifters to make the long duration cam streetable at idle. http://www.rhoadslifters.com/
The engine builder recommended I use 15-40 Rotella years ago but I like the synthetics idle stability with the Rhoads lifters.
I have 10-40 AMO in there now but was looking at the AME 15-40.
I noticed my engine seems to run a little stronger right before full warm up with the oil pressure right at 20 at idle, it usually drops to 15 at idle when fully warmed up (160-170 degrees).
My car stays in a heated garage and is only driven in nice weather.
What would be the performance difference between the two?
Thank you,
Jeff
Thank you,
Jeff
