Polyproplyne should degade lower then 320F ..I think they don't recommend more then 150F for a working temp. 320F may be the extrusion temp used to form the stuff as a molten polymer (I used this stuff in extrusion and that temp sounds about right).
Cotton cartridges have a Type 304 stainless steel core. Maximum temperature is 250° F.
Polypropylene cartridges have a polypropylene core. Maximum temperature is 150° F.
Costs are for comparison only. Actual costs would probably be lower.
............ss core...................pp core
Size gpm Each Each
0.5 2
4535K41 $21.45 4535K71 $17.27
1 2
4535K51 22.60 4535K81 18.15
3 3
4535K53 27.40 4535K83 23.87
5 4
4535K43 17.68 4535K73 14.52
10 4
4535K55 24.30 4535K85 21.00
25 5
4535K45 15.77 4535K75 12.67
50 5
4535K57 21.94 4535K87 19.09
75 5
4535K59 21.00 4535K89 18.38
100 5
4535K47 14.28 4535K77 11.82
350 5
4535K48 14.28 4535K78 11.82
There's not much cost advantage of PP over a SS core filter in our scale of use.
If you can cool your oil below the melting temp ..PP has the advantage (Schultz - thank you) of being able to be totally incinerated.
BUT ...if you wanted to make a offline drip filter for used oil for makeup or whatever, I think that it would be a fairly quick deal. It wouldn't be as fine or as cheap as TP ..but would probably last a good while.
Anyone wanting a cheap(er) source for these types of filters ...I think I still have a contact for them by the case ..in just about any length/diameter and um rating (thanks to FG).
