Poly swaybar bushings - greaseable or not?
West Michigan
Going to be doing ball joints, maybe control arms and endlinks on the mustang before the weathe turns this fall and thinking it would be a good time to do swaybar bushings as well. In the past I have run greasable energy suspension P.U. swaybar bushings on other vehicles and even with frequent greasing they would squeak A LOT. I always just used my regular gun loaded with regular chassis grease, though.
Not in the market to pick up another grease gun and load it with fancy grease like superlube or others that people like for their poly bushings. This isn't exactly a sealed application, either, so I'm wondering if there is ANY benefit to non-greasable bushings for me?
See if PolyGRAPHITE bushings are available for your vehicle instead of straight polyurethane. I've had no squeaking issues at all with polygraphite bushings. No grease required, last much longer than replacement rubber bushings do.
