I just ordered my test kits from Polaris. I'm planning on doing a Virgin analysis on Phillips 66 5w40 Guardol XT. I thought I would do the initial test and ask for the TBN. Then I was planning on asking for the TAN on all the used oil analyses that will follow. For now I only plan on testing for one of my vehicles to try and make sure it is safe to extend the intervals a little bit.
The vehicle is a Jeep Wrangler with a 3.0L Ecodiesel. It is deleted. From what I've seen from others testing these things are super hard on oil. I was going about 5000 miles for an OCI. Then we moved and this last one I think I went almost 8000 miles. It crept up on me. With a delete they seem to be a lot better on fuel dilution and shearing. I am also going to run a remote filter and bypass filtration. Which should take me from around 9 quarts to 13 quarts capacity...ish. The Manual calls for 10,000 mile OCI's but I haven't seen very many analyses that look good at anything much beyond 6k-7k. When the MS-12991 spec is adhered to anyway.
So yeah do I need to do the TBN first and then switch to TAN? Or just do TAN first and then all the way through? I've seen mention that sometimes certain oils show a low TBN as the way they are blended it just works out that way. Maybe it doesn't matter that much in the long run but I figure I can at least try to get it right for the VOA Diesel Oil Database
