BMW Canister Filters (K&N, Mann, Mahle): After removing old filter and just prior to draining old oil, I put the new filter in the canister after drizzling a bit of new oil on the pleats, turn it upsidedown, and fill 50-70% full and halfway through the process I flip the filter over while keeping the canister upsidedown. Then, after pouring the new oil in, wiping out the oil filter area on the block, I pour the oil from the canister (that wasn't absorbed by the filter) into the filter hole on the block, and then screw it on and start it up. I have never gotten an oil light with this method, and the first start is in no way different from a regular start (as far as I can see/hear, nor does it take longer). I do not know that there is any benefit to this, but it takes all of 3 extra minutes, I always take plenty of time on oil changes or other work on my cars (cathartic), and yes it gives me a peace of mind that while not based in fact is a good feeling nevertheless.
I do wonder, though, if my method of pouring oil prevents the occurrence of high-pressured air shooting through the system?(cartridge holds 2/3qt if full with filter in it, but I do not fill it all the way, instead to usually about 3/4 full sometimes half, and the filter soaks up about 1/3-1/2 of that, though I typically add 5.5qts thru fill hole, about 0.25qt soaked into filter, 0.3-0.4qts from canister into oil filter "well", and the remainder of the last bottle which is about 1/3-1/2qt is poured into filter "well" immediately before pouring from canister and installing filter)
It seems possible, or that it may minimize the risk, but I have no way to know...? Anyone?
Other Cars ("regular" twist-on filters; K&N, RP, M1, Bosch): prefill as much as possible first thing to let the media soak, and pour the excess into the oil filter well immediately before screwing in filter then starting the car. Same results as above.
