- Joined
- Mar 20, 2022
- Messages
- 22
Hello folks,
I have a 2018 Golf R manual transmission. I figured I may as well replace the transmission fluid at 50K miles and a new clutch, and a Stage 1 tune that makes more torque than before. I'm generally happy with the OEM fluid except that first thing in the morning and on colder days it gets a little crunchy. Around here, the coldest it gets is just below freezing. I'm not sure what OEM fluid to run as there's been a few part numbers over the years. Aftermarket or OE is fine too, as long as it is similar or even less crunchy. The tuner recommends a 75W-90 and notes that it will be crunchier at low temperatures. No thanks. I don't launch or race the car, so not clear if I need the extra protection a thicker oil gives.
