I bought the truck about 3 years ago. When I bought the truck it had a small knocking sound, which just sounded like a lifter to me. It had 195,000 miles on it and were all highway miles. I ran a check on the vehicle and it had no recorded accidents and showed regular tune ups and oil changes.
I bought the truck and had it serviced including spark plugs and transmission fluid and filter.
I had my 2002 Ford F-150, which has 244,000 miles on it, in the Ford Service department for a Free Service Inspection they were offering on Monday. The main reason for the inspection was because the knocking has gotten alot worse. Still hears like a lifter tapping and now a knocking.
Upon inspection, they came back with the results and recommendations.
Has a bad valve.
Cooling flush
Battery
Power Steering
Engine Leaking Oil-Unable to determine leak
Brake Fluid
Horn Inoperable
Front Pinion Seal on Rear Differencial-Small Leak 1.5
Rear Differencial Fluid slightly burnt
Fuel Filter
Air Filter
Front Pads
Front Rear and Shocks
Transfluid
They proceeded to try and find the oil leak. Washed the engine all up and let it dry. Started it up and was unable to find where the leak was coming from. Said they could put dye in and let me run it about a week to determine where it was coming from.
Next day they called and recommended for the oil leak
Valve Covers
Front Cover
Oil Pan Gasket
All for just $2500. That's not including the rest of their recommendations. Or an new engine for $7500.
I told them I don't have that kind of money to put into a vehicle with that many miles.
Here IS what I had them do.
Brake system flush
New front brake pads
Air filter
Fuel filters
Spark plugs
New rotars
New pcv valve
I did not let them do the
Valve covers
Front cover
Oil pan gasket
Horn
Coolant flush
Battery
Power steering flush
Pinion seal
Rear differencial flush
Shocks
Transmission flush-was afraid it might mess up the transmission
I am seriously considering using Permatech engine oil stop leak for the engine leaks
and Lucas transmission fix stop slip for a transmission leak they say it has.
I would appreciate any opion you may have.
My son is using this truck in San Angelo and it is his ONLY means of transportation to and from work and to get his wife to the baby doctor. I haven't actually had the chance to look at the truck and my son knows nothing mechanical about vehicles.
I know that the horn doesn't work, and the steering jerks occasionally when turning. The truck never runs hot. Sometimes while at a red light with the brake applied it seems like it still wants to move forward.Probably could use shocks at some point.
I don't know that there is anything that could be done about the knocking and I'm not even sure what that knocking is. Actually sounds like a lifter tapping along with something knocking.It does sound pretty bad though.
Top Edit Reply Quote Quick Reply Quick Quote Notify
Previous Topic
View All Topics Index
Next Topic
Quick Reply:
HTML is disabled
UBBCode is enabled
Add Signature
Has a bad valve.
Cooling flush
Battery
Power Steering
Brake Fluid
Horn Inoperable
Fuel Filter
Air Filter
Front Pads
Transfluid
Valve Covers
Front Cover
Oil Pan Gasket
Brake system flush
Air filter
Fuel filters
Spark plugs
New rotars
New pcv valve
Valve covers
Front cover
Oil pan gasket
Horn
Coolant flush
Battery
Pinion seal
Shocks
Previous Topic
Next Topic
Quick Reply:
HTML is disabled
UBBCode is enabled
Add Signature
