ATF maintenance is a overdue on my 03 passat 5spd tiptronic (aka 01V) . As the car was purchased used at 60K and now 72K, the transmission fluid is probably the original factory fill; probably overdue for a change.
I am, of course, open to suggestions, but I'm thinking I can accomplish a nearly-entire fluid flush by performing a few drain-and-fill's over the course of a few days. I also would replace the filter but haven't decided when in the sequence of drain-and-fills to perform that step.
I've scoured the internet for suggestions, recommendations, veats ,etc with quite a myriad of results.
The Bentley manual says to use synthetic atf: VW G-052-162-A2
ZF says to use Esso-LT71141
Valvoline's letter of 7-June-2004 says its Mercon-V is ok for a lot of things (including BMV's with LT71441 and Honda ATF-Z1 except cvt's but does not even list VW's)Coastal's multi-vehicle synthetic blend shows ZF approved on its label.
I also see ATF-4 being mentioned in the threads with WM's Super-tech being quite popular.
Being value-conscious and not brand-loyal, I'm looking for the least expensive solution that meets the performance specs.
Any comments on my drain-and-fill approach ?
Any suggestions for ATF?
