OK, you guys shamed me into getting an OBDII code scanner so now you have to help me figure out how to use it (just kidding, of course). Here are a couple questions on the output on my Actron CP9575:
1999 Toyota Avalon 1MZFE V6 - According to Toyota, output from A/F sensors at 2500rpm should fluctuate +/- .08v (.7-.62v) and, after quick deceleration from 4k to idle, output should spike up to .76v. On my car, output is barely changing at 2500rpm - about +/- .04v. And, output spikes to only .72v instead of .76v on decel from 4k. Is this good enough or are my A/F sensors getting lazy? Thanks.
2010 Acura MDX - Wow, this car has so many PID outputs it makes my head swim. Problem is there are many multiple outputs. For example, I have 3 Coolant Temperature outputs. Is this the same sensor displayed 3 times for some reason or is it showing me three different sensors. If they are different sensors, how do I know which is which? Thanks.
