I want to know it all. Please tell me about resting voltages. Surface charge. States of charge. Discharge. Why shaking a battery is bad, another advice I had to un-learn, and which probably helped me kill my old battery with a shorted cell. When the poles reverse. What a soft cell is. Continuity. If side posts are better than top post. When batteries have both, if you can use either or. What a good voltage is, for resting voltage. How a smart charger works. If I should get a super-duper whizbang 7800 smart charger, etc. If a 3300 desulfates. if CTEK or NOCO is best. If the Power Pulse desulfator I bought that will hook onto the top and stay in the truck is any good. All of it.
Backstory: I purchased a new battery, a few days ago. Let it run for about 20 minutes with high load, and no alternator, as per my wiring and charging woes, which should disappear after I connect back that ring terminal I left off, and improve all grounds. Battery had 14.7V when the car was running, after being discharged for 20 minutes (run with no alternator and loads of fan and radio and headlights on. Did this to deplete a surface charge.) I left it on my smart charger for two days straight, and it always levels out to 12.9V. I sometimes hear people say the resting voltage is supposed to be 13.2V, at 2.2V for each cell; then EricTheCarGuy says 12.6V for when it is in a vehicle.
The battery is 5 days old, it has spent about 20 minutes being discharged intentionally to break a surface charge, and it has spent about an hour being used with the alternator on, and a certain alternator wire disconnected. It is a NAPA, with 540CCA. Appears sealed.
Please educate me about battery behavior. I do not want to run down and destroy this one. And so far, it appears like the alternator is wired up correctly and that won't happen, so please educate me about the heart of the system, the battery.
