JHZR2
Staff member
Ive never jacked a car up to put it on jackstands. Ive sometimes jacked a car up with a hydraulic jack, but that is it. Everything else has gone by ramp or dealer/indy shop.
I need to get my 82 MB up high, but not on ramps, as I want to service it in my garage, out of the elements, to do an oil cooler hose.
This car is high enough off the ground that I do not even put it up on ramps to do an oil change, FWIW.
Anyway, jacked it by a crossmember just behind the engine (after taking the pb off and the AT into N position, wheels chocked), which is where it is recommended to do. I then used OTC US-made jack stands, on their lowest setting (high enough for me) in the boxed section of the unibody, offset by some wood.
I recognize the wood is not optimal, Ill need to use a 2x6 or whatever fits in the saddle best. I want wood to protect the body from metal on metal.
I then used two smaller jackstands, not to support, but as extra protection, under the crossmember that I jacked the car up on.
Thoughts/suggestions????
Thanks!
Thanks!
