Ok, so yesterday I tackled my brakes and rotors in my 2004 Buick Rendezvous FWD. It's a 4 wheel disc brake system. Replaced the rear shocks while I had everything apart too.
When I went to put it together the front driver side tire wouldn't snug up completely. Tried twice and exchange tire and there was still play in the wheel (could rock it a little.) Doesn't seem to matter if it 3 and 9 or 12 and 6 o'clock position. There was also a lot of grease on the back of the caliper and in that area too. CV, but would it cause my symptoms, bearings, suspension parts?
Tried pumping up the brakes and torquing to final spec and there still was some play which wasn't present on the other side.
On a separate note, this is the first car I've done brakes on that back that use a shoe-type emergency on the inside of the rotor. How far should one back the adjuster wheel? When I spun the back wheels it seemed like the emergency brake light rubbed against the new rotors. Condition-wise the emergency brake system looked good condition with lots of lining left. Is he acceptable or do I need to back it up more?
