I'd remove 1/2 a gallon of water from each 5 gallon bottle.
I would guess (but am not certain) that the effectiveness is directly proportional to the concentration. Undiluted, it's rated down to -100 F. With none of the waterline antifreeze at all, pure water would freeze @ +32 F. Therefore, I'd expect that at 50% strength (i.e. half water/half antifreeze), I'd expect it would protect down to about -34 F.Picked up a jug of this.
I usually add a quart to the toilet tank and bowl. Now I read on the back, product cannot be diluted for it to work as intended. So I can't mix it with water? Then what do people use it for?
Use that in the toilet. If it freezes, there is no give to porcelain, so it WILL break.Picked up a jug of this.
Why not store them in a warm space? Avoid all this drama.
Would they suffer any damage if I left them full and they froze? I don't keep heat on.
Is that an early-'70s Valiant or Dart?You mean this?
Lifted the front with my tow truck and pulled it forward enough to get in the drivers door.
I can only speak for myself. I did not expect your water to be on. Otherwise you would not be using water bottles.This is BITOG. Nothing surprises me anymore. I was expecting to get a bunch of questions asking why I don't have the water on or aren't I using the sewer system and not paying for it every time I flush.
72 DartIs that an early-'70s Valiant or Dart?
Technically I think you're ok because you're using water from home which would be the same sewer system. I suppose if you used rain water, then you never paid for the water.This is BITOG. Nothing surprises me anymore. I was expecting to get a bunch of questions asking why I don't have the water on or aren't I using the sewer system and not paying for it every time I flush.
What if the water comes from one municipality and the sewer system is in another ?Technically I think you're ok because you're using water from home which would be the same sewer system
They might share the same waste water treatment plant though. But if not, it's probably close enough for government work, I don't think there's really a sewer police.What if the water comes from one municipality and the sewer system is in another ?
It was a joke, hence the big grin emoji....They might share the same waste water treatment plant though. But if not, it's probably close enough for government work, I don't think there's really a sewer police.
