The FSM states the limit to be 0.0006" to 0.0014" for clearance. If the after my measurements (after honing), the clearance is slightly off, because of piston skirt wear, am I able to just replace the suspect piston with replacement standard size piston, or do I have to re-bore and replace ALL pistons?
What is one to do, to rectify the situation. The machinist who did the hot tanking and honing told me the clearance is 4 thou, and the limit is 2 thou. I'm going to do the actual measurements at home myself tonight.
