Hi everyone, I have a 285k miles 01 Corolla with a 7AFE engine that is consuming oil. At the 250k miles the engine has overhauled with new piston & rings, bearings, gasket and seals but the block wasn´t bored in a machine shop because it looked in good shape, it didn´t had any ridge in the top part of the cylinders. At 273k miles the engine overheated because of a faulty radiator cap, it bent the cylinder head and whe had to send it to a machine shop so it would be flat, we changed all the gasket of the cylinder head including the valve stem seals.
The engine has always used 20w50 oil and it consumed 0.8 qts every 1k miles, then I began to read in this forum that thick motor oil isn´t always the best so I decided to give HDEO 15w40 a try and now the engine is consuming 1.1 qts every 1k miles. I´m planning to do 1 more oil change using an HDEO 15w40 to see if the extra detergents help clean the engine (which isn´t very dirty by the way, but cleaner is always better) and then I want to try the old 20w50 again to see if it lowers the oil consumption.
What I wanted to know is if you think that a piston soak could help me to reduce the oil consumption rate? What I think is that the new rings have only 2-3 years and 35k miles, my guess is that they aren´t stuck, I think that the real problem is that they lost flexibility in the last overheat which happened at 273k miles. Would a piston soak help me?
The valve seals have only 12k miles and I dont see any signs of worn valve seals, the PCV valve was checked in less than 3k miles ago and it wasn´t blocked and it sounded like it should when I shaked it, I could even blow with my mouth and it let the airflow go to one side and it caused a restriction sucking (just like it should, because it is like a check valve). I also cleaned it.
What products would you recommend to do a piston soak? I´m in Venezuela so the products that you might use aren´t avaible here, what I have in mind to use is:
- Injector Cleaner
- Kerosene
- Diesel
- Carburetor Cleaner
- Acetone
- ATF
- Engine Flush for oil
I recently took the spark plugs out to see the piston tops and they look very shiny, they have just little pieces of carbon in them, I think is because they are only 35k miles old.
- Injector Cleaner
- Kerosene
- Diesel
- Acetone
- ATF
