Originally Posted by DriveHard
Originally Posted by OVERKILL
Originally Posted by aquariuscsm
I wonder if it's like car audio amps that on paper claims to be megawatts but realistically puts out around 25 wpc.
Class D amps are more efficient, but yes, there's also some marketing in play here citing "peak" wattage versus what the amp is able to deliver on a continuous basis. Kind of reminds me of the PC speakers and cheap stereos that were marketed with ridiculous power spec's in the late 90's because they went by peak wattage.
There is some hype in the claims...but they do put out some healthy power. A good rule of thumb for those Behringer amps is to divide the claim by the square root of two...that usually gives you a realistic RMS value. I have one of the iNUKE NU3000 for each of the subs. They claims 3000 watts in bridged mono into 4 ohms, and it bench tests right around 2000 watts.
Yup, I'd say that's a reasonable position on the matter.
I have a pair of old Yorkville professional amps here (made right here in Ontario) that I used to use to drive some speakers before I bought the Bryston. They are Audiopro 3000 units, pretty beefy but I think actually weigh less than the Bryston. They, like the iNuke's, are actively cooled. The manual has a date of January 1990
These quotes are pulled from it:
Originally Posted by Yorkville
All amplifiers with ratings above 1400 watts rely on the fact that the average power required to reproduce music is considerably below the maximum power the amplifier is capable of providing. Some amplifiers are capable of actually delivering their rated power continuously, but these may consume as much as 50 amperes in doing so. To get around this problem, many high power amplifiers are shipped with either a special high current plug on the line cord or with two line cords. In practice, the user is often forced to find some way to connect these products to standard line outlets. Due to the lower average power required by music, this will sometimes work, but there is the possibility that circuit breakers in the concert hall will trip in the middle of a performance. The AUDIOPRO 3000 is internally capable of delivering its rated power on a continuous basis. However, rather than leaving the question of energy management to chance, the AUDIOPRO 3000 incorporates active energy management circuitry which continuously monitors the actual power consumed from the AC line. Should that exceed an average of 12 amperes over a sustained period, the AUDIOPRO 3000 will reduce its output power and therefore its power consumption accordingly.
The AUDIOPRO 3000 is a high efficiency amplifier which is capable of delivering a greater percentage of its input power to the speaker load than most other amplifiers. Under actual operating conditions its power conversion efficiency approaches that of digital switching amplifiers. However, digital switching amps are still plagued by poor specifications and cumbersome operating constraints. The AUDIOPRO 3000 provides the superior transient response and low distortion figures associated with the best and most reliable analog designs.
Historically, bridged mode operation was a means of getting high power from medium power amplifiers. The AUDIOPRO 3000 delivers more power from one channel than most other amps deliver when fully bridged. Bridging the AUDIOPRO 3000 will reproduce music with a headroom of about 4500 Watts into a 4 ohm load! We don't know of any subwoofers that can handle such power. We recommend that you carefully check the ratings of your speaker system against the power specifications listed in this manual before you consider bridging the AUDIOPRO 3000.
It also includes this (very honest) spec page that lists actual output figures including THD.
You can see that they will produce 425W/channel at 8ohms under the same conditions as the Bryston, but with more THD.
