Still trying to get my DSL working upstairs. It works fine off the test jack in the network interface box.
(Fairpoint Communications in upstate NY)
The "new" adapter in the interface box has a hinged cover over 4 tabs (3 orange, 1 blue). One puts a wire pair in the tab and pushes it up to lock that pair. The phoneman said to use the blue tab if I am only using DSL (no voice), otherwise an orange tab.
Two questions:
1) Will the wires going to the 4 tabs work if the hinged cover is opened up?
2) How does one run inside house wire to the tabs and still be able to close the hinged cover.
Thanks
Two questions:
Thanks
