My truck has oiled bearings in it. I am going to do some work on the front wheels and was thinking of packing them with grease instead of oil this time.
The truck is just a toy and does not carry any weight. It originally had greased bearings in it and someone replaced the seals and added oil hubs to it.
It sits alot and when it does it leaks some oil out, even with new seals. Leaking hub seals are a big problem if I get pulled into any open scales and inspected.
I don't think grease will leak much or maybe none even with a worn seal.
Should I use Moly grease or regular Lithium based grease? Stuff I can find at the local auto parts store should be ok?
