Have you ever had a problem so frustrating that you've come close to ripping your eyeballs out? Well, I'm dealing with that now. My upstairs shower developed a leak into my basement - thankfully the room below it is the furnace room with no drywall. I recently installed a new glass shower door, cleaned everything up, perfectly installed GE Silicon II caulking (the best of the best), and it was fine for about 2 months, then started leaking. I checked all the grout and tile, everything looks fine, so I re-caulked it. 2 months go by and it's fine and has recently started leaking again. It only leaks when weight is in the shower basin - ie when someone takes a shower. I just did all the testing - filled the basin with water and let it sit over night - no leak. It didn't even leak when I stepped in the basin and stood there for 15 minutes listening to the freakin radio. So I take a shower - waterfall into the basement. I just ripped out the new door and got on my hands and knees and inspected everything - the best I can tall is, it's been leaking before I got the house because the boards below the shower are fairly rotted. There's some big gaps between the wall and the shower basin on the exterior, I'm guessing from contracting and expanding from leaks. That leads me to believe that the whole darn thing flexes so much that after 2 months, the caulking starts cracking and ripping off the surfaces from excessive movement, and the waterfall begins.
So now I have to take a half day from work and get someone in here to look at it and likely rip the whole [censored] thing out and install a new shower insert. I want to rip the tile off and get one entire molded shower "thingy" for lack of a better word. That way there's no tile grout or sealing issues ever again.
Thanks for letting me rant.
