So, I have a very basic load tester I got from Harbor Freight the other day. I let the car sit for at least 3 hours after sundown and hooked up the tester. It read at about 12.6V. I engaged the actual load and the voltage dropped to around 10 and stayed there. I only held the load for about 5 or 6 seconds, but it didn't raise nor did it fall, however. It also didn't go really far down and then raise to 10. Translation, marginal battery?
After load testing twice, for no more than 7 or 8 seconds at most, the voltage at the battery without load read at around 12.3 or so volts.
The car still starts etc, but come this summer this may leave me stranded or what? It's the little Civic so IDK, maybe this is causing the alternator to put back too much and I risk needing an alternator($150+) vs. a battery($75 @ Costco)?
I've heard 9 or lower with a load test is a 'bad' battery.
Thoughts or advice is appreciated. Thank you.
