People with high mileage vehicles who run supertech full synthetic oil
Nice. Looks clean.
Here’s a clean 5k.
I just wanted to fully understand the 2 scenarios regarding Subaru's in this thread.
Scenario #1: danjak26 (the thread starter)'s parent's Subaru has 150,000 miles on it and was using Super Tech High Mileage Full Synthetic 0W-20 oil at 10,000 mile OCI, and posted pictures showing extremely clean internals, but danjak26 never used Valvoline R&P on his parent's Subaru. Danjak26 - please confirm this is correct.
Scenario #2: Glenda posted her pictures after the final 4th Valvoline R&P 5,000 OCI, that were also extremely clean.
Possible takeaway from this is that Super Tech High Mileage Full Synthetic can handle 10k OCI in a Subaru engine that is tough on oil,
but the Valvoline EP that Glenda used at 5k OCI could not.
Or perhaps the high engine temps in Glenda's Subaru due to mountainous driving played a role? What do you think Glenda?
I’m squarely in severe service. IMO that’s the difference. Also remember my engine has always looked spotless but my rings were not. My friend that runs low cost oil at 5k oci’s in the same conditions is getting visual deposits. Also uses oil. Now the two 3.5’s show obvious differences visually. My only guess is different base oils handle high heat differently.
How are you seeing "extremely" clean internals? You are only seeing a miniscule shot with the camera and light..
Whoa is that second photo (deep varnish) the starting photo for the M1 ESP cleanup after QS?
Correct no VRP ever used in my mothers subaru.
The super tech oil here is made by Warren. I do not use it exclusively but over the years have used various names made by Warren.
Jeep 208k
FJ 226k
Both daily driven and both currantly have traveller oil in them. Don't know who makes that
I believe it may still be Martin Lubricants
I am not a mechanic or an automotive engineer or a tribologist, but I am of the opinion that if a few basic guidelines are followed (change oil and filter every 3K-5K miles/6 months), that most people would be totally satisfied with using Super Tech oil. Are there "better" oils, oils that do certain things better? Sure, but how much better? If using nothing but Super Tech gets you 300K miles, do you really care?
I like the way this guy thinks
Until you are the one adding oil every fill up wondering why when you did 3-5k changes.
My old Corolla was on conventional mostly QS, not syn, with 3k changes and by about 150k was pretty much 1qt per 1k miles. Yup, I had a quart in the trunk and every fill up ~300 miles, 1/3 got added religiously until cleaned up with a different regimen and oil additive.
At 220k when totaled there was no sludge or anything just a light varnish color but always looked clean through fill port also.
