Pentius PLB7317-12 PK
Good decent low cost oil filter.
I bought a case and sent 1 to BrendanC, he cut open and posted pics of new PLB7317 filter.
Made in CHINA.
There's a 20% coupon now, taking the cost down to $19.95. I didn't really need another case but at that price I couldn't resist.
I've cut open a 3614 and a 6607 after running them and both were in good shape and seemingly well made. I'll eventually be running them on all my vehicles.
These will also work for quite a few SxSs, although may be a little too long for some applications
From what I have seen, it looks like the 7317 and the 6607 are the same thing, expect the 7317 is a little longer. Same bypass set point. In fact, I think a lot of the cheapy quick lube places only carry the 6607, so likely a lot of vehicles that spec the 7317 are running around with a 6607 spun on.
What is the difference other than a silicone ADBV?
It looks like the media is a little different. The extended life says 99% at 20 microns. The standard filter doesn't publish a rating that I see (I may be wrong, but I don't see one.) Having used the Extended life, and cut open the filter here on BITOG, the media does appear to be different. The extended life also has a silicone ADBV and a silicone gasket.
  • Like
Reactions: GW.
Same filter as the parts plus I have. Easy 5k intervals and probably the whole length of the OLM. I paid less than $2 a piece though.
  • Like
Reactions: GW.
These are the best deal going for 3-5k oci’s IMO.
Thanks for your assessment.
Would the Pentius PLB $2 filter be better made than the Super Tech and Purolator Tech filters?
Also, does the Pentius PLB $2 filters have any visible defects that could leak unfiltered oil?
Yes.
No, same bypass design as the PLXL.
Amazon seems to either be out or no longer selling the case of the pentiums extended life filters. Any idea where to buy them at reasonable price?
