First time posting one of these and Second post on the forum, Let me know if i screwed anything up =P
Not sure if i need to list this? Bu i don't expect many of you to be familiar with the engine type. I'll also list some of the mods that i think could influence wear.
Car: Ford Falcon XF
Engine: 4.1ltr 6 cylinder Ford crossflow on EFI. Alloy head, Cast iron block, Hydraulic Flat tappet cam and Pushrod with roller rockers.
Increased valve lift (530thou) and valve spring pressure (110lb)
Work this OCI: Highway driving(80%), race(10%) and drag strip (5 passes)
Power: 220RWHP
4699km
Penrite HPR30 (20w60) full mineral oil.
Oil usage during OCI: Nil
Oil Added: Nil
Oil filter: Ryco Z9
KM since last engine work: Cam + lifters + timing set replaced 15,000-20,000km ago
Aluminium: 10
Chromium: 1
Iron: 45
Copper: 8
Lead: 7
Tin: 1
Silicon: 12
Sodium: 3
Water (% by crackle): Viscosity (cSt,40ºC): 175
PQ Index: 24
Here is the actual report:
http://i346.photobucket.com/albums/p425/...zpsa1af0af6.jpg
Seems to be missing a lot of the information you guys usually get?
Viscosity was found low for oil type, Since changed to full synthetic Penrite Racing15 and HE Donaldson filter.
Car: Ford Falcon XF
Power: 220RWHP
4699km
Oil Added: Nil
Oil filter: Ryco Z9
Aluminium: 10
Chromium: 1
Iron: 45
Copper: 8
Lead: 7
Tin: 1
Silicon: 12
Sodium: 3
PQ Index: 24
