This is a friend's UOA running on PZ 15w-40 in So. FL as per my recommendation. He has a 1.8t but report says 2.8 so I dunno if universal averages are correct. 118k miles on engine. I listed it as PZ/Rotella because it probally is repacked Rotella. Looks good for a cheap oil. I caution against trying to repeat this stunt in cooler temps w/ turbo engine. Here's what I've got>>>
Blackstone Commments: Good even wear, go 7000 next time.
__R/A__
Al 2/3
Cr 1/0
Fe 5/8
Cu 1/5
Pb 1/5
Sn 0/1
Mo 56/48
B 24/42
Si 7/7
So 6/14
Na 2364/2179
Mg 7/196
P 947/792
Zn 1105/950
SUS Visc- 70-83/76.1
FP +396f
Insolubles .4
http://periodic.lanl.gov/default.htm
Also, a primer for noobs on interpreting UOAs I tried to compose. Please correct/expand on it, it's just a start of a Tech Article for kindergardners.
UOA means Used Oil (lab) Analysis and is just that. The same spectrometer analysis can be done a virgin unused oil, a VOA. A VOA obtains elemental information on the unused oil product, determining the amounts of various chemicals inside the oil. There are also some other physical tests like flashpoint and final visc. Those chemicals which are made up of various elements (mass spec tests for basic elements, not chemial compounds) and those elements perform various functions. Some are Ant-Wear (ZN) some are Extreme Pressure additives that only come into play in certian situations and some are Frictin Modifiers (Mo). Some elements are are part of Detergent/Dispersant Package (Ca,Na) and some modify the oil's physical properties. I won't try to explain fully which are which because some perform multi-functions and there is a newer additives, Antimony (Sb), which Blackstone does not yet test for. (Mobil Clean) Common sense rules on elements and their function- for example, Zink is not a detergent!
The USED Oil Analysis differs in as it contains data about the used oil itself, the remaining detergents, AW and such, but also the wear metals from the engine. This is most usefull as different metals correspond with diffrent areas of the engine. AL or Fe is the block, Pb or Cu is the bearings, Cr or Cu are the rings, etc. I'll try to post a VOA of Rotella for comparison.
[ February 11, 2006, 12:14 AM: Message edited by: Auto-Union ]
__R/A__
Al 2/3
Cr 1/0
Fe 5/8
Cu 1/5
Pb 1/5
Sn 0/1
Mo 56/48
B 24/42
Si 7/7
So 6/14
Na 2364/2179
Mg 7/196
P 947/792
Zn 1105/950
FP +396f
Insolubles .4
