I never understood why folks say use heavier weight oil in hot weather; does not make a lick of sense. Besides lubricating, engine oil is to cool the engine.
Oil flowing faster, the more it cools; a thermal dynamics thingy-bob. Heavier weight oil does not flow as well, cannot dissipate heat as well as lighter weight oil such as 20 weight oil, thus heavier weight oil does not cool nor lubricate as well. In hot weather to help cool the engine we need more oil flow, not less oil flow.
Regardless of the ambient temperature, 0 degrees or 100 degrees, the fully warmed engine is at the 200-ish temp. Thus when ambient air is hot why use thicker oil, the engine is not effected by that ambient temperature; remember it is operating within itself at the 200 degree range?
Living in Metro Atlanta we have horrible commute traffic, gridlock stop and go. This year we had 90 day of 90 degrees or more; one day short of a record. My cars contain either 0w-20 or 5w-20 oil. Also, during the hot summer on long 70 MPH road trips it contains the same oil. On a run out to Oregon and back same oil.
If the engine temperature gauge starts climbing out of normal range we need more oil flow to help cool it. We also should have our cooling system checked as well. It could have plugged radiator fins, thermostat not performing properly, radiator fan not kicking in as it should, any number of things. Putting in heavier weight oil for hot weather is not an option
My DD is a 2004 Xterra, oil capacity is 3.5 quarts of oil, including the filter.
