Originally Posted by bbhero
Originally Posted by demarpaint
Similar issue with my E-150. I cheaped out and went with an aftermarket PCV valve and went from zero oil use to a quart in about 1,500 miles. I bought a Motorcraft PCV valve and oil use stopped again. I will not use aftermarket PCV valves as a result. As a matter of fact I won't use aftermarket thermostats or sensors either. Flame suit on.
I think you are right about this my friend... ^^^^^
I lament having a aftermarket thermostat put in my lady's Camry... Though it has been fine thus far knock on wood.
And I'd bet good money Trav would agree with you also.
I would. While a simple device a PCV valve must be properly calibrated (usually through spring selection) during manufacture to work as it should in the engine it was designed for. The shake and clean business may or may not bring the valve back to optimal operating specs, it does nothing for spring tension loss.
As with thermostats and other parts, years ago you could buy a decent aftermarket product but quality has been going downhill for years and now with all the third world outsourcing quality and QC has become sketchy.
An out of spec PCV (it doesn't even have to be stuck) can cause sludge, deposits and oil consumption. This is a good article and worth reading.
http://www.agcoauto.com/content/news/p2_articleid/197
